Outside lights routine doesnt always work
Hi.
I have a couple of routines set on my outside lights.
1st one is at sunset outside lights turn on 100% brightness every day.
2nd outine is at 22:00 every day outside dim to 50% and turn off after 2 hours (midnight)
Recently when i come home in the last month ive had 2 or 3 times where the lights are at 50% at about 6pm.
When i check the history of the device it states they came on at sunset at 50%???
Never had issues before. I have deleted the device and linked it again and set up the routines again and was good for a week or so.
brand/model of outside lights?
can you post screenshots of the Routines being used?
Try removing “Turn On” from routine. Leave dimmer percentage.
Cant im afraid. Have to select 1 of the 3
Only thing i can think is its turning on at the same level it last turned off, and its just ignoring the 100% bit
You can have dimmer set, and have turn on disabled.
Set dimmer value, and uncheck Turn On
Oh yeah, that worked. I thought i tried it.
Thanks for that. Hopefully that will do the job.
Cheers
