Full log showing an update. "from live log"
SYLVANIA Smart Gardenspot mini RGB
7b205fdd-cd08-4298-8540-3da2173a174e 22.15.08: debug description is read attr - raw: 39480303000A0100002000, dni: 3948, endpoint: 03, cluster: 0300, size: 0A, attrId: 0001, result: success, encoding: 20, value: 00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.53: debug description is read attr - raw: 39480303000801002000, dni: 3948, endpoint: 03, cluster: 0300, size: 08, attrId: 0001, encoding: 20, value: 00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.53: debug [name:level, value:100]
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.53: debug description is read attr - raw: 39480300080A00000020FE, dni: 3948, endpoint: 03, cluster: 0008, size: 0A, attrId: 0000, result: success, encoding: 20, value: fe
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.51: debug [name:switch, value:on]
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.51: debug description is catchall: 0104 0006 03 01 0040 00 3948 00 00 0000 01 01 0000001001
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.49: debug description is read attr - raw: 39480303000800002000, dni: 3948, endpoint: 03, cluster: 0300, size: 08, attrId: 0000, encoding: 20, value: 00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.49: debug description is catchall: 0104 0300 03 01 0040 00 3948 00 00 0000 07 01 00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.46: debug [raw:0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0D00, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3948, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0D, 00], clusterInt:32801, commandInt:0]
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.46: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0D00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.46: debug description is catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0D00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.45: debug [name:level, value:100]
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.45: debug description is read attr - raw: 394803000808000020FE, dni: 3948, endpoint: 03, cluster: 0008, size: 08, attrId: 0000, encoding: 20, value: fe
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.45: debug description is catchall: 0104 0300 03 01 0040 00 3948 00 00 0000 07 01 00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.42: debug [raw:0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0C00, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3948, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0C, 00], clusterInt:32801, commandInt:0]
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.42: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0C00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.42: debug description is catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0C00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.41: debug [raw:0104 0008 03 01 0040 00 3948 00 00 0000 07 01 00, profileId:0104, clusterId:0008, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:3948, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:8, commandInt:7]
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.41: info DID NOT PARSE MESSAGE for description : catchall: 0104 0008 03 01 0040 00 3948 00 00 0000 07 01 00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.41: debug description is catchall: 0104 0008 03 01 0040 00 3948 00 00 0000 07 01 00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.40: debug [name:switch, value:on]
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.40: debug description is on/off: 1
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.39: debug [raw:0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0B00, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3948, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0B, 00], clusterInt:32801, commandInt:0]
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.39: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0B00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.39: debug description is catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0B00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.37: debug ON/OFF REPORTING CONFIG RESPONSE: SmartShield(clusterId: 0x0006, command: 0x07, data: [0x00], destinationEndpoint: 0x01, direction: 0x01, isClusterSpecific: false, isManufacturerSpecific: false, manufacturerId: 0x0000, messageType: 0x00, number: null, options: 0x0040, profileId: 0x0104, senderShortId: 0x3948, sourceEndpoint: 0x03, text: null)
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.37: debug description is catchall: 0104 0006 03 01 0040 00 3948 00 00 0000 07 01 00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.34: debug [raw:0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0A00, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3948, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0A, 00], clusterInt:32801, commandInt:0]
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.34: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0A00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.34: debug description is catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0A00
7b205fdd-cd08-4298-8540-3da2173a174e 22.14.34: debug Configuring Reporting and Bindings.
7b205fdd-cd08-4298-8540-3da2173a174e 22.13.32: debug [name:switch, value:on]
7b205fdd-cd08-4298-8540-3da2173a174e 22.13.32: debug description is on/off: 1
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.29: debug description is catchall: 0104 0300 03 01 0040 00 3948 00 00 0000 07 01 89000100
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.26: debug [raw:0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0700, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3948, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[07, 00], clusterInt:32801, commandInt:0]
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.26: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0700
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.26: debug description is catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0700
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.25: debug description is catchall: 0104 0300 03 01 0040 00 3948 00 00 0000 07 01 89000000
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.22: debug [raw:0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0600, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3948, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[06, 00], clusterInt:32801, commandInt:0]
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.22: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0600
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.22: debug description is catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0600
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.21: debug [raw:0104 0008 03 01 0040 00 3948 00 00 0000 07 01 89000000, profileId:0104, clusterId:0008, sourceEndpoint:03, destinationEndpoint:01, options:0040, messageType:00, dni:3948, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[89, 00, 00, 00], clusterInt:8, commandInt:7]
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.21: info DID NOT PARSE MESSAGE for description : catchall: 0104 0008 03 01 0040 00 3948 00 00 0000 07 01 89000000
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.21: debug description is catchall: 0104 0008 03 01 0040 00 3948 00 00 0000 07 01 89000000
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.18: debug [raw:0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0500, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:3948, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[05, 00], clusterInt:32801, commandInt:0]
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.18: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0500
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.18: debug description is catchall: 0000 8021 00 00 0040 00 3948 00 00 0000 00 00 0500
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.17: warn ON/OFF REPORTING CONFIG FAILED- error code:137
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.17: debug description is catchall: 0104 0006 03 01 0040 00 3948 00 00 0000 07 01 89000000
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.12: debug description is read attr - raw: 39480303000A0100002033, dni: 3948, endpoint: 03, cluster: 0300, size: 0A, attrId: 0001, result: success, encoding: 20, value: 33
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.10: debug description is read attr - raw: 39480303000A0000002033, dni: 3948, endpoint: 03, cluster: 0300, size: 0A, attrId: 0000, result: success, encoding: 20, value: 33
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.08: debug [name:level, value:80]
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.08: debug description is read attr - raw: 39480300080A00000020CB, dni: 3948, endpoint: 03, cluster: 0008, size: 0A, attrId: 0000, result: success, encoding: 20, value: cb
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.06: debug [name:switch, value:on]
7b205fdd-cd08-4298-8540-3da2173a174e 22.12.06: debug description is catchall: 0104 0006 03 01 0040 00 3948 00 00 0000 01 01 0000001001
