Hi Doctor,
Appologies but I missed your first reply. I have the following actions working:
B1 press\hold\stop hold
B2 press (I have misplaced hold somehow, its not even logging in catchalls)
B3 press\hold\long hold\stop hold
B4 press\hold\long hold\stop hold
B3 and B4 were working fine before, but the updated code should hopefully solve any potential variation by correctly resolving using source endpoint IDs rather than relying on the Cluster IDs and commands.
I have updated the binding to capture the devices, it should have been obvious at the start but each button has a different source endpoint ID (indeed I use it to detect the presses of 3 and 4).
Have some code, updated bindings, fingerprint and button actions. I’ve not tried your fingerprint yet but worked out that my own one was being interfered with by another test DTH I had setup. All seems to add nicely now. Name has been changed so I can revert quickly back to my old one.
* OSRAM 4 Button Switch Handler
* Copyright 2017 AnotherUser
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Modified from code written by motley74 and sticks18.
* Original source: https://github.com/motley74/SmartThingsPublic/blob/master/devicetypes/motley74/osram-lightify-dimming-switch.src/osram-lightify-dimming-switch.groovy
metadata {
definition (name: "OSRAM 4 Button Switch Classic", namespace: "AnotherUser", author: "AN") {
capability "Actuator"
capability "Battery"
capability "Button"
capability "Configuration"
capability "Refresh"
capability "Sensor"
attribute "zMessage", "String"
fingerprint profileId: "0104", deviceId: "0810", inClusters: "0000, 0001, 0020, 1000, FD00", outClusters: "0003, 0004, 0005, 0006, 0008, 0019, 0300, 1000", manufacturer: "OSRAM", model: "Switch 4x EU-LIGHTIFY", deviceJoinName: "OSRAM 4x Switch"
simulator {
// Nothing to see here
tiles(scale: 2) {
standardTile("button", "device.button", width: 6, height: 4) {
state "default", label: "", icon: "st.unknown.zwave.remote-controller", backgroundColor: "#ffffff"
valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
state "battery", label:'${currentValue}% battery'
standardTile("refresh", "device.button", decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
main "button"
details(["button", "battery", "refresh"])
log.debug "Parsing '${description}'"
// TODO: handle 'numberOfButtons' attribute
// Parse incoming device messages to generate events
Map map = [:]
log.debug "parse description: $description"
if (description?.startsWith('catchall:')) {
// call parseCatchAllMessage to parse the catchall message received
map = parseCatchAllMessage(description)
} else if (description?.startsWith('read')) {
// call parseReadMessage to parse the read message received
map = parseReadMessage(description)
} else {
log.debug "Unknown message received: $description"
//return event unless map is not set
return map ? createEvent(map) : null
def configure() {
log.debug "Confuguring Reporting and Bindings."
def configCmds = [
// Bind Button 1 and 2. No Change from source.
"zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0006 {${device.zigbeeId}} {}",
// Bind Button 3 and 4. New cluster IDs.
"zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0300 {${device.zigbeeId}} {}",
// Bind the outgoing level cluster from remote to hub, so the hub receives messages when Dim Up/Down buttons pushed
"zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0008 {${device.zigbeeId}} {}",
// Bind the incoming battery info cluster from remote to hub, so the hub receives battery updates
"zdo bind 0x${device.deviceNetworkId} 0x01 0x01 0x0001 {${device.zigbeeId}} {}",
//ToDO: Determine what other clusters are on there and how they can be used. What purpose do 0003, 0004, 0005, 0019, and 1000 have?
"zdo bind 0x${device.deviceNetworkId} 0x02 0x01 0x0006 {${device.zigbeeId}} {}",
"zdo bind 0x${device.deviceNetworkId} 0x03 0x01 0x0006 {${device.zigbeeId}} {}",
"zdo bind 0x${device.deviceNetworkId} 0x04 0x01 0x0006 {${device.zigbeeId}} {}",
"zdo bind 0x${device.deviceNetworkId} 0x02 0x01 0x0300 {${device.zigbeeId}} {}",
"zdo bind 0x${device.deviceNetworkId} 0x03 0x01 0x0300 {${device.zigbeeId}} {}",
"zdo bind 0x${device.deviceNetworkId} 0x04 0x01 0x0300 {${device.zigbeeId}} {}",
return configCmds
def refresh() {
//Straight copy. Need to check device and clusterID for battery.
def refreshCmds = [
zigbee.readAttribute(0x0001, 0x0020)
//when refresh button is pushed, read updated status
return refreshCmds
private Map parseReadMessage(String description) {
// Create a map from the message description to make parsing more intuitive
def msg = zigbee.parseDescriptionAsMap(description)
//def msg = zigbee.parse(description)
if (msg.clusterInt==1 && msg.attrInt==32) {
// call getBatteryResult method to parse battery message into event map
def result = getBatteryResult(Integer.parseInt(msg.value, 16))
} else {
log.debug "Unknown read message received, parsed message: $msg"
// return map used to create event
return result
private Map parseCatchAllMessage(String description) {
// Create a map from the raw zigbee message to make parsing more intuitive
def abc = "zdo active 0x${device.deviceNetworkId}"
log.debug "cluster ID is $msg.clusterId"
log.debug "message from source $msg.sourceEndpoint"
//New content follows
switch(msg.sourceEndpoint) {
//Endpoint numbering runs top left, top right, lower left, lower right.
case 1: //"physical button 1"
Map result = [:]
if (msg.command==01){
result = [
value: 'pushed',
data: [buttonNumber: 1],
descriptionText: "$device.displayName button 1 was pushed",
isStateChange: true
else if (msg.command==05) {
result = [
value: 'held',
descriptionText: "$device.displayName button 1 was held",
isStateChange: true
else if (msg.command==03) {
result = [
value: 'stophold',
descriptionText: "$device.displayName button 1 stopped being held",
isStateChange: true
log.debug "Parse returned ${result?.descriptionText}"
return result
break
case 2: //physical button 3
Map result = [:]
if (msg.command==76){
result = [
value: 'pushed',
data: [buttonNumber: 3],
descriptionText: "$device.displayName button 3 was pushed",
isStateChange: true
else if (msg.command==03){
result = [
value: 'held',
descriptionText: "$device.displayName button 3 started to be held",
isStateChange: true
else if (msg.command==01){
if(msg.data[0]==1){
result = [
value: 'longhold',
descriptionText: "$device.displayName button 3 continued to be held",
isStateChange: true
else if (msg.data[0]==0){
result = [
value: 'stophold',
descriptionText: "$device.displayName button 3 stopped being held",
isStateChange: true
else{
result =[
descriptionText: "$device.displayName button 3 unknown data in command 01",
else{
result =[
descriptionText: "$device.displayName button 3 unknown command",
log.debug "message data $msg.data[0]"
log.debug "message command $msg.command"
return result
break
case 3:
//physical button 2
Map result = [:]
result = [
value: 'pushed',
data: [buttonNumber: 2],
descriptionText: "$device.displayName button 2 was pushed",
isStateChange: true
return result
break
case 4:
//physical button 4
Map result = [:]
result = [
value: 'pushed',
data: [buttonNumber: 4],
descriptionText: "$device.displayName button 4 was pushed",
isStateChange: true
result = [
value: 'held',
descriptionText: "$device.displayName button 4 started to be held",
isStateChange: true
if(msg.data[0]==3){
result = [
value: 'longhold',
descriptionText: "$device.displayName button 4 continued to be held",
isStateChange: true
result = [
value: 'stophold',
descriptionText: "$device.displayName button 4 stopped being held",
isStateChange: true
else{
result =[
descriptionText: "$device.displayName button 4 unknown data in command 01",
else{
result =[
descriptionText: "$device.displayName button 4 unknown command",
return result
break
//ToDo: Look at how to capture hold down of buttons 3 & 4, it doesn't differentiate on cluster or command as per B1 and B2 .
//Motley obtained from other examples, converts battery message into event map.
//AN: I don't think this is working yet.
private Map getBatteryResult(rawValue) {
def linkText = getLinkText(device)
def result = [
value: '--'
def volts = rawValue / 10
def descriptionText
if (rawValue == 0) {
} else {
if (volts > 3.5) {
result.descriptionText = "${linkText} battery has too much power (${volts} volts)."
} else if (volts > 0){
def minVolts = 2.1
def maxVolts = 3.0
def pct = (volts - minVolts) / (maxVolts - minVolts)
result.value = Math.min(100, (int) pct * 100)
result.descriptionText = "${linkText} battery was ${result.value}%"
return result
