Orvibo S25 with Smartthings
I recently got two orvibo S25 wifi smart plugs from primecable for under $40. I thought it should be compatible with old S20 smart plug but it’s not. They don’t have UDP 10000 open which means you can not use the old script.
There are two ports open, UDP 5000 and UDP49153.
Any idea to get it work with Smartthings?
The little box was updated from 52.25.57.215/10001;tcp. Not sure what that server is.
Looks like this one will not work with Smartthings hub. Buyer beware!
If I blocked that IP at my firewall, I will not be able to control that device. It will say server timeout.
