The new firmware includes changes that “break” some functionality in the previous device handlers, but also allows for much improved functionality.
In order to fix the issues and add improved functionality, I have updated all Xiaomi / Aqara Button device handlers (DTHs). All SmartThings v2 & v3 Hub users are encouraged update to the newest DTHs immediately.
Please see this post for all details and links to the updated DTHs.
The code of these updated and improved device handlers is open source and free.
But if it has helped you, a coffee / beer donation is always very much appreciated!
PayPal: Venmo: @KeithPG
Uhmm got it to add the button as a thing, battery is showing, got the automation set up with smart light, everything works from the classic app but nothing happens if i press the button no change of status in the app, nothing… am i missing something? my smartthings samsung button works like a charm
Xiaomi devices are close to conforming to the zigbee standards that they connect and work after a bit of playing but aren’t strictly following the standard so there are some issues with them. I’ve always added mine then an hour later the device would drop and I would reset it and join it again and they would then stay connected. The best way to see what the issue is is to check the logs of the device when you push the button to see if the logs even reflect the push if not then reset the button and rejoin it or if it had been working for weeks or more and suddenly stopped then just try replacing the battery.
Xiaomi / Aqara devices require the use of a custom device handler (also known as “DH” or “DTH”). Basically think of it as a device driver.
My post right before yours links to post in another thread dedicated to Xiaomi / Aqara devices that is a recent update of device handlers for a number of different Xiaomi / Aqara button models.
You will need to log into what’s known as the SmartThings Groovy IDE. Click on the Locations tab, choose your locations, and then click the My Device Handlers tab where you can add the corresponding custom device handler for your button. This is done by creating a new device handler, copy-pasting the code, and clicking the [create] button at the bottom of the web page. The code to copy from will be found in the corresponding link of the post I mention above.
Then since you’ve already added the button and it’s showing up as a “Thing” (meaning no device handler has been assigned), you need to assign the correct device handler to it. This is also done while logged into the SmartThings Groovy IDE, in the My Devices tab. Find the button, click on its name to view its details, scroll down and click [Edit], and in the pop-up menu next to Type: (which refers to “Device Type”, the name given in each device handler), find the correct device name, for example “Xiaomi Aqara Button”, which will be down near the bottom of the list because that’s where custom device types are found. Then save, and you can start using the button in the “classic” mobile app (Xiaomi / Aqara devices aren’t fully supported in the new Samsung Connect mobile app).
Thanks Veeceeoh! I already used the code to create the DTH before adding the button through the classic app. Just checked into the IDE and the button already has the type Xiaomi Zigbee Aqara Button AQ2 maybe I don’t have the right DTH code?
HI, thanks, I removed the old one and the device handler, added your code for my model WXKG11LM. Classic app found it right away. Went to change the type. But it always shows in Released… even when i press the button Any idea?
The display of the button status is a kind of “hack” that I came up with to make the UI for the button device handlers more useful. As such, due to the nature of SmartThings executing code “in the cloud”, the display of the button status may be slow or not display at all. However, the actually button 1 pushed event will always work (unless ST is down, which does happen).
So… you should double-check whether a pushed event occurs by looking at the Recently tab for the button while viewing it in the ST “Classic” app.
If you don’t see the correct events occurring there, then I can help with live logging output. You’d want to enable the display of “info” and “debug” log messages in the preference settings for the button (by clicking the gear icon while viewing the button in the ST “Classic” app). The Live Logging settings toggles are at the bottom, so scroll down:
After pressing [save] then open up the SmartThings Groovy IDE for your hub and change to the Live Logging tab so that log messages can be viewed while pressing / holding / etc. the button. That’s what I’d need to see if events aren’t occurring.
uhm interesting cause you know i have a aquara motion sensor also that i tried to configure in the past that is in the drawer, could it be that it interfered with the adding of the button? i’ll remove the battery from the motion sensor, remove the button and tried again the process of pairing
No it wouldn’t interfere. That message is from one specific device only, the one you have named “Office Button”. And that message would never be produced by an Aqara motion sensor either. The only Aqara device that sends messages on cluster: 0101 and attrId: 0505 is the Vibration Sensor.
Can you take a screenshot of the device details page in your hub’s IDE? It will look like this:
So you must have confused your Aqara Vibration Sensor for the button. Some sellers call it a “Motion Sensor” but that is confusing because there is already a PIR (“person in room”) motion sensor from Aqara. So I only call it the Vibration Sensor.
Yes, I have made a SmartThings device handler for the Aqara Vibration Sensor. The latest version is v0.92b, but the best explanation of how to use it is in this post:
PLEASE NOTE: The feature to change the sensitivity level does not work yet. I have got it working for another similar hub, called Hubitat Elevation, so I have been looking at a method to get the feature working in the SmartThings device handler.
I have a weird problem. I’m using bspranger’s DTH for Xiaomi Zigbee Button - Model WXKG01LM.
It pairs well and reports the correct status (Single click, double click, held) but the aim for me to get this is to be able to control Alexa routines. For some reason, Alexa is not discovering this device.
I’ve successfully paired the Xiaomi Motion Sensors and Door/Window Sensors, and both were discovered by Alexa.
Any idea what could be wrong? I’m pulling my hair out trying to figure it out (I’m not a tech guy…)
