[UPDATE] Aqara Button device hander to v1.2
Available immediately on the bspranger/Xiaomi GitHub repository. The updated code can be copied from this direct link.
New features
- Compatible with the new Aqara Button model WXKG12LM, which offers single-click, double-click, hold, and shake functions (see table below)
- Compatible with Aqara Smart Light Switch models WXKG02LM / WXKG03LM (with limitations, see Important Notes, below)
- Button status correctly displayed in main tile of mobile app UI, with a new custom icon
- Live logging preference settings, with toggles for display of info (“plain” English) and/or debug (technical) log messages. As a default, info log messages are displayed.
- Improved webCoRE support
Aqara Model WXKG12LM Functions Table
Button action | Event sent to hub |
single-click | button 1 pushed |
hold | button 1 held |
double-click | button 2 pushed |
shake | button 3 pushed |
Note: the hold function is hardware-based, activated after 400ms according to Xiaomi’s specifications - which cannot be changed
Important Notes
Limitation: The “original” Aqara model WXKG11LM, and both models of Aqara Smart Light Switch only support button
pushed
. There is NO possibility of adding a hold feature for these models. - Limitation: The 2-button Aqara Smart Light Switch model WXKG02LM is only recognized as ONE button. This is because the SmartThings API ignores the data that distinguishes between left, right, or both-button presses.
- webCoRE users can make use of a number of custom attributes, some of which have been renamed from the previous version of the device handler:
•lastCheckinCoRE
- updated on every single message received from the button
•lastPressedCoRE
- updated when the button is physically pressed (or shaken, for model WXKG12LM)
•lastReleasedCoRE
- model WXKG12LM only updated when the button is physically released after being held - The device handler no longer sends
button released
events. This is because SmartThings’ button capability only supportspushed
andheld
events. - The toggle mode option has been removed, because SmartThings’ button capability doesn’t support
button released
events and also because most Smart Apps that work with buttons offer a toggle switch option already. - The SmartThings app UI display of “pushed” (or for model WXKG12LM, “single-clicked”, “double-clicked”, or “shaken”) lasts for about 1 second, and then will reset back to “released”. When model WXKG12LM’s button is held, the UI will display “held” until the button is physically released, but note that the
button 1 held
event is always sent after the button has been held for 400ms.
