I’ve only seen it happen now and then. No idea how to change it, because as far as I have seen, it’s based on messages sent directly by the hardware.
<— This one, right?
The wall surface-mounted Aqara Smart Light Switch model WXKG03LM can be used with the Aqara Button DH.
Sadly, the hardware only supports sending a button pressed message. There’s no multi-click or hold support.
Beware: The two-button Aqara Smart Light Switch model WXKG02LM does NOT work as two buttons with SmartThings. The technical reason for this is that the SmartThings ZigBee attribute report message parser strips out what is known as the endpoint number value. The two-button WXKG02LM model uses a different endpoint number for the left button press, right button press, and both-button press. The DH only receives all of those messages as coming from one button. Until SmartThings changes the way it handles ZigBee attribute reports with different endpoint numbers, the two button functionality of the WXKG02LM model will never work.
