I am communicating with an ESP32-H2.
Sometimes I get an INVALID_VALUE line in the logs.
For example, when I send a message to increase the heatingSetpoint.
2025-02-17T19:44:45.230378662+01:00 INFO Espressif Airco Control <ZigbeeDevice: 9763dd9f-71e7-42e1-9963-aee010751371 [0xD301] (Espressif Airco Control)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD301, src_endpoint: 0x08, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Thermostat >, lqi: 0xFF, rssi: -68, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x31, ZCLCommandId: 0x04 >, < WriteAttributeReponse || < WriteAttributeResponseRecord || ZclStatus: INVALID_VALUE, AttributeId: 0x0012 > > > >
Is the above message sent from the ESP32 device?
I guess so since I see: “src_addr: 0xD301, src_endpoint: 0x08”. But I want to be sure since I do not see anything of activity on the ESP32 device.
So, can I be sure that the above message is sent by the ESP32 device, or is there a possibility that this message is generated by the Smartthings Hub itself?
