+1 to get this fix and supported in Smartthings.
I also got this device, and If it can work with the SmartThings hub, then Iâd go buy one today! Whatâs the status, is this still not supported?
Still not supported
booooooooooooooooooooooooo
Iâve ordered another timer from Lowes. I know, this one doesnât even work properly and Iâm getting another! Iâve âkindaâ got it setup and working for my needs. I used one of the device types above. I then exposed the switch via the API. Then setup a cron job on my web server to run on the days and times, or to turn the device ON through the API. Iâve made it turn on every minute during the time period I want to water and the reason for that is to make sure it turns on because sometimes it does not, as people have noted above. I donât have an off, because the timer only runs for 10 minutes. So by having the cron job run from say 4am to 5:50am means I should get the device on from 4am to 6am. Then because the device sometimes gets lost or others come onto the network I set an every 5 minute job to do a refresh call through the API, to wake it up. I have noticed battery % has gone down 20% in 2 weeks though. I also noticed every day 2 or 3 new devices popping up. Not sure what thatâs about. The original entry works. I just add the new devices then remove them.
Iâm hoping to get another one, on order, should be here in 2 weeks, and then have it setup similar to above for a different area of my yard.
Would be better to just do everything in SmartThings, and also have it run reliably. But for now Iâll have to make do with my cron jobs.
Any timeframe on when it will be supported, or work in-progress to get it supported?
I have two of these orbit timers, one watering plants in the front of my house & one in the back. Since they water 6x a day on short cycles, if I miss one its no big deal.
They seem to work mostly reliably using a simple schedule & auto rain delay, but I keep getting new duplicate devices show up in ST randomly - sometimes after a hub reboot. If I delete them, new ones just start coming back eventually. Currently I have 17 âunconfiguredâ orbit timers in addition to the two working ones. It appears that each new one is getting a different network ID.
If I could just work around this duplicate device problem so I could have a clean dashboard, I could live with the rest of the quirks. I understand thereâs no official support yet, but any ideas out there on a workaround to prevent all the duplicates?
Now it doesnât work at all! Last night my cron job switched it on 90 times (once a minute, from 4am to 5:30am) and it did not turn on once! Crazy!
I canât seem to turn it on from the ST app, or the through the API. Then suddenly it goes on and I canât turn it off.
I doubt this is going to be supported by the end of the season. We should form a betting pool.
I came to the conclusion that the physical Orbit device itself is not reliable and eats batteries. Even when using the manual timer controls on the device itself, every once in a while it would make a soft click noise but actually fail to turn on or, worse, off. It also needs new batteries every 6 or 7 weeks or so with relatively light usage. Unfortunate SmartThings never made the firmware update to support it, but I donât think the Orbit is reliable or battery efficient enough for me to keep using. Still looking for an alternativeâŠ
Can someone tell me how to put it into pairing mode. I canât get it to be recognized as anything. Iâve had it in use for a few weeks without it being paired to anything.
it goes into pair mode when you put new batteries in it. Stays in pair mode for like 5 min
We have major water restrictions in-place. (Who would have thought in Canada!) Not even allowed to use my soaker hose.
Anyway, thatâs bad news for me, but good news for SmartThings! They now have another year to sort this thing out.
I have an orbit Drip System valve model 27087 and I have gotten it to work, at least during my testing. I will set up a new drip system later.
It connect to my ST Hub as a Zigbee Load Control Switch which is a device created by George Richards here: https://community.smartthings.com/t/leviton/15498
I have it running a schedule created by a smartapp based on the template âSmart Turn it onâ which allows me to schedule it by day of the week, by hour and then the length of time. I removed the presence stuff in the template.
I like it! I have three non-wireless Orbits already and I will replace them as needed.
Nick, that link doesnât work. Says I donât have access. Weird. Could you post again, or a link to the source.
Realized could make a smart app for the current device. Basically if timer turned on, which sets the device to water for 10 minutes, make it that each minute while on, send an on to the device, until the device is turned off, and so if it runs again the following minute it will see the device is off so donât turn it on. Thinking out aloud. May need a virtual switch, or maybe not.
This way, when the device is turned on, it stays on until specifically turned off.
I could then get rid of my complicated crontab setup calling the API, and use the smart app mentioned above by Nick to schedule the timer all within ST.
I also cannot get to the link It is getting to end of season here in Ohio, but would still like to have it working
Yeah, I found that out a few months ago - thereâs a hidden forum that supposedly doesnât have much, except when it has something you need.
@April - can you help here?
How do you get access to the hidden forum. I have orbits timers and like them, but would like to move to the Iris timer.
FalcoGeorge has been communicating with me via the mail system on this forum.
It seems that others canât access these communications. Sorry.
Hereâs the device âdriverâ to add to your âdevice Typesâ in your IDE, developed by FalcoGeorge.
He cautions that it is a rough pass at the issue:
metadata {
// Automatically generated. Make future change here.
definition (name: âZigbee Load Control Switchâ, namespace: âGR_Load_Controlâ, author: âGeorge Richardsâ, oauth: true) {
capability âSwitchâ
command "on"
command "off"
fingerprint profileId: "0104", inClusters: "0000,0003,0006", outClusters: "000A"
simulator {
// simulator metedata
status âonâ:"on/off: 1"
status âoffâ:âon/off: 0â
reply "zcl on-off on":"on/off: 1"
reply "zcl on-off off":"on/off: 0"
tiles {
standardTile(âswitchâ, âdevice.switchâ, width: 2, height: 2, canChangeIcon: true) {
state âoffâ, label: âOffâ, action: âswitch.onâ, icon: âst.Outdoor.outdoor16â, backgroundColor: "#ffffff"
state âonâ, label: âOnâ, action: âswitch.offâ, icon: âst.Outdoor.outdoor16â, backgroundColor: â#53a7c0â
main "switch"
details([âswitchâ])
log.info description
if (description?.startsWith(âcatchall:â)) {
def value = name == âswitchâ ? (description?.endsWith(" 1") ? âonâ : âoffâ) : null
def result = createEvent(name: name, value: value)
def msg = zigbee.parse(description)
log.debug "Parse returned ${result?.descriptionText}"
return result
log.trace msg
log.trace âdata: $msg.dataâ
else {
def name = description?.startsWith(âon/off: â) ? âswitchâ : null
def value = name == âswitchâ ? (description?.endsWith(â 1â) ? âonâ : âoffâ) : null
return result
// handle commands
def on() {
log.debug "Executing âon()â"
sendEvent(name: âswitchâ, value: âonâ)
âst cmd 0x${device.deviceNetworkId} ${endpointId} 6 1 {}â
âzcl on-off onâ
def off() {
log.debug "Executing âoffâ"
sendEvent(name: âswitchâ, value: âoffâ)
âst cmd 0x${device.deviceNetworkId} ${endpointId} 6 0 {}â
âzcl on-off offâ
As I said, it works for me on the Orbit valve.
I use a modified smartapp to turn the valve on for 2 minutes and then turn it off. I ignore the fact that when it is first turned on it starts a 10 minute countdown.
Hereâs the app I modified:
- Smart turn it on-modified
- Author: sidjohn1@gmail.com
- Date: 2013-10-21
definition(
name: âSchedule Drip Systemâ,
namespace: âsidjohn1â,
author: "sidjohn1@gmail.com",
description: âSchedules drip system.â,
category: âConvenienceâ,
iconUrl: âhttps://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.pngâ,
iconX2Url: âhttps://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience%402x.pngâ
preferences {
section(âWhich Valve?â){
input âswitchOneâ, âcapability.switchâ,title:âSelect Valveâ, required: true, multiple: true
section(âOn which Days?â) {
input âdayOneâ, âenumâ, title:âSelect Daysâ, required: true, multiple:true, metadata: [values: [âMonâ,âTueâ,âWedâ,âThuâ,âFriâ,âSatâ,âSunâ]]
section(âAt what time?â) {
input name: âtimeOneâ, title: âSelect Timeâ, type: âtimeâ, required: true
section(âFor how long?â) {
input name: âtimeTwoâ, title: âNumber of minutesâ, type: ânumberâ, required: true
def installed() {
if (timeOne)
log.debug "scheduling âDrip Systemâ to run at $timeOne"
schedule(timeOne, âturnOnâ)
def updated() {
unsubscribe()
unschedule()
if (timeOne)
def turnOn(){
log.debug "Start"
def dayCheck = dayOne.contains(new Date().format(âEEEâ))
def dayTwo = new Date().format(âEEEâ);
if(dayCheck){
switchOne.on()
def delay = timeTwo * 60
runIn(delay, âturnOffâ)
def turnOff() {
switchOne.off()
Hope this helps.
Just updated mine. The device works great! Will report back on the app on the next automated run
