According to the help text for the Search options, I should be able to refine my searches of the forum using, for example, max_age:7 to only look for content from the last seven days.
The search results, however, seem to completely ignore this - I’m getting posts from two years ago included in the result set.
Am I misinterpreting the limited help text that is there?
Considered that, tried it, but nope…it doesn’t work with the Google search option either.
Google treats “max_age:7” like just another text search term - its not like “site:abc.com”, for example, where Google interprets that to mean only include content from abc.com.
Surely “Min” = Minimum, and the set of articles with a minimum age of 14 days are those which are 14 days old or older.
Conversely, “Max” = Maximum, and the set of articles with a maximum age of 14 days are those which are 14 days old or newer.
E.g.
I have a set of articles which are 4, 5, 10, 15 and 24 days old.
If I wanted only the articles from the last two weeks (maximum age 14 days) then I should get back 4, 5 and 10.
If I wanted articles two weeks old or older (minimum age 14 days) then I should get back 15 and 24.
I tried it, and it does indeed behave as you’ve described.You really need to explain this in the help text, because I’ll bet pennies to pounds the majority of people will not be expecting that behaviour.
Aha - I agree completely with “max 14 == all numbers up to 14”
(I.e. 0, 1, 2, 3, 4, … , 12, 13 and 14 but NOT 15, 16, 17, … 24231, 24232, … etc.)
Therefore, does it not logically follow that max_age:14 is all ages up to 14 but nothing over that?
(0, 1, 2, 3, 4, … , 12, 13 and 14 days old, but NOT 15 days, 16 days, 17 days, 2 years, 3 years and six months, … etc.)?
My confusion arises because right now, max_age:14 is returning everything OVER 14 days old, not UNDER 14 days old.
