Hi,
I accidently deleted my garage door contact sensor from smartthings. How do I tell smartthings to refresh and pick it back up so I can see it again?
I have a vista20P connected via an evisalink
Hi,
Generally, you put the mobile app in add device, make sure your hub led blinks and reset your device so that it gets attached again like new.
The reset procedure will depends on the devices.
For instance smartthings sensors: remove the battery, press the white small button while you insert the battery again.
