Okay mixed news on this front. I installed the hub and app, easy enough. I then put one of the scene controllers in include mode and the hub found it right away! Same with one of the dimmer switches. So I can control the dimmer switch, that’s great!
Then I figured out that I can make an “automation” to turn that light on at some preset dim level and another to turn it off. Okay, good.
What I have not figured out how to do is to associate a button on the 4 button scene controller with those automations. In fact, if I click on the scene controller (from the “My Home” page) I see the scene controller, and if I click on it I see an odd icon and two little plug receptacle icons, one labeled ON and the other labeled OFF. They don’t do a thing. I think I need to install a “smartapp” to give me the rest of the buttons, but I can’t find one.
If I have to replace my scene controllers, that’s not the end of the world. I have only 3 of them. But on the Smartthings storr, under “things” I don’t see any multi button controllers. I’m thinking there must be a way to do this, short of going back to Vera.
Can someone point me in the right direction?
Thanks!
UPDATE:
The scene controllers are Leviton RZCS4
Apparently some scene controllers can send commands to a hub while others just talk directly to other Z-Wave devices. Bottom line, I think I need some kind of multi button device that mounts in a wall switch box and send commands to the hub, which commands can then be assigned to automations. Right???
