Is there a way to display the offline devices in home dashboard?
It used to work before the last update
Beats me. I have noted elsewhere that the offline notification doesnāt seem to be displayed if SmartThings Now is disabled and that you can close the notification and that is the last you see of it. However I just canāt get it at all now. I have cycled a hub on and off and ST knows it is offline but there isnāt any evidence of it on the home screen.
There doesnāt seem to be an option to include Offline Devices in the Dashboard any longer, even with āSmartThings Nowā enabled.
If your device(s) support offline diagnostics, you can see them in Menu->Offline Diagnostics. If not, then it appears the only way to see them is Home->Manage Hubs where you will see a list of your hubs with the number of Connected and Not Connected devices. If you then click on the hub you will get a list of the Connected and Not Connected devices for most hubs (not the Wi-Fi hub apparently).
No, they seem to have switched Offline and Low Battery notifications to use larger tiles in the SmartThings Now area. Iāve also had a message from Sleep Environment Report there.
Iām rather assuming that appliance alerts will also appear there but I donāt have any Samsung appliances.
The Dashboard now seems to be exclusively for tiles that always have a current status to report.
When I first got the app update I had Offline notifications displayed but I havenāt seen them since I closed the notifications even though new devices are offline. To me they are more effective than the little dashboard tiles for alerting purposes but only if they remain visible until the alert condition has passed. As things stand I have devices that are in offline and low battery states and nothing on my Home tab is telling me about them and there seems to be nothing I can do about it.
Though I feel not displaying the offline devices at all must surely be a bug, using dismissable notifications for offline and low battery events may be a design choice. If so then I I feel it is a poor one.
Ok, so do you only get the ST Now dialog if it is enabled at the time the device goes offline? I ask because I have a device that is offline and I enabled ST Now and I didnāt get any offline devices dialog/pop-up.
I have not seen any offline devices getting posted as offline in the SmartThings Now tile. I have several offline and one that went offline this afternoon but nothing appears in SmartThings Now.
I do see low battery devices appear in SN.
When I first updated my apps they displayed an Offline device tile for the currently offline device at the top of the Home tab, screen wide and stacked with other suggestion type tiles. They had a button bottom left to open the Offline diagnostics tool and one bottom right to go direct to the settings of the tool to exclude devices from the check.
My recollection, possibly confused, is that if I excluded the device the tile disappeared and if I reinstated it the tile came back. If I disabled SmartThings Now the whole stack of tiles disappeared and came back when it was enabled again. If I closed the tile with the X it disappeared and it has stayed away.
As the only offline devices I currently have are ones Iāve deliberately switched off I assumed that Iād effectively dismissed a notification and Iād have to wait for the list of offline devices to change. However try as might the tiles havenāt returned.
Pls, please Samsung. give ua the buttons offline and lowbattery back.
They are shown randomly. and especially with some Ikea Matter devices I want to see it instantaniously. The AWA is an alternative, and also the ādiagnose offlineā But I just want those two buttons.
Even Offline diagnostics isnāt as reliable as it has appeared to me for the last few days. I just added an offline device to a control-only account and it was adamant that all eleven devices were connected fine despite the app knowing fully well the extra device was offline. Yet under the Location owner account it works correctly.
I am also rather baffled by the expand/collapse functionality for Favourites. Is this yet another custom UI implemented by the app rather than respecting the presentations in the API? Or will the presentations support expanded tiles? Why is it only implemented for Favourites? Why not Rooms? Indeed why do it at all?
Although I feel the old Dashboard needed some work, mainly to give users better control over the layout and sizing and to better highlight the dynamic tiles, the replacement has lost important functionality, and the critical functionality doesnāt seem to work at all.
I lost sensors on dashboard after I did a delete data on this in android. This last update is a disaster. About half of the devices I press on donāt do anything at all. Seems like the things like sensors mostly. Lights I canāt even turn on and off without clicking them first.
ETA: They are working mostly finally, but took a few hours it seem to sync with the app. Usually took maybe 5 minutes before.
And sigh, now the app just seems to freeze up and even crash often. What a mess.
On one locatoin I just do not get offline info after"Analizing" hwat did I do wrong. How get it back. It is a remote location where offline devices may disturb my heating automation.
I find Smartthings Now maybe mothers little helper, but for now. No idea how to edit it.
I wish I knew. Although I have seen the Offline tiles on two Locations on two phones, since closing the tiles I have not seen them ever again. Thatās a few days now. I thought perhaps theyād just implemented the tile as a one off notification (not a completely absurd idea, but not what I would prefer) and Iād have to wait for a new offline event for a new one but Iāve had several of those with no joy.
I find the āAnalyzingā is a bit random too, and now it is starting to be irritating because it is almost always followed by an unwanted Sleep Environment Report suggestion.
I had a Low Battery tile pop up the other day. I closed it because it was a bit in my face and it hasnāt been seen since. Now I donāt know if Iāll ever see one again.
I actually quite like the idea of a big tile that can be dismissed, but only in combination with a little one that canāt, and only if it actually works.
Hey Michael!
Handling UI display updates and tracking state changes is always tricky after software updates kind of like managing visibility settings and layouts when youāre tweaking your own web tools. Have you checked if a recent update changed the default filter toggles or card grouping options on the home dashboard? Hopefully, they add a quick toggle back for offline devices soon
New app is pretty nice, but please Samsung, give us the count of offline devices back in the dashboard. It is by far the fastest way to see if there are any offline devices in need if attention.
