Just curious if anyone has tested this themselves? Ive tried a couple times and it just wont work. Every single device just shows no network.
I had my internet go out today and i wanted to control some things and ofcourse, nothing… i tried on all 3 of my ssids. I made sure i turned off data, and still… nothing..
You can see in the pic on the top right it shows wifi is connected, and exclamation point is due to no internet connection.. but yet i was still able to connect to my routers gui.
Do you have ‘Switch to mobile data’ (or the equivalent) enabled on your phone? I know you said you disabled mobile data and it would make more sense for the phone to stick with the Wi-Fi in that case, but Android networking doesn’t seem to place much importance on that. Certainly SmartThings seems to have been told there isn’t a network available at all.
Are there any good articles explaining how it works behind the scenes? I’d like to test this feature but am unsure about the prerequisites for offline control.
On WiFi only Android and iOS devices (aka tablets), it works as long as I’m connected to the ‘same’ network (IOT network in my case) that the SmartThings Hub(s) are on before the Internet is lost.
As for my Android phone(s), like you I’ve had no luck at all in airplane mode or with mobile data off using WiFi.
So, I connected to my IOT network with a USB Ethernet adapter connected to my Android phone. In airplane mode, the SmartThings app prompted me to turn off airplane mode. With mobile data off, it prompted me to connect to a WiFi network.
Oh well, my Android cellular devices aren’t capable of doing SmartThings offline mode apparently. So, my old Android WiFi only tablet that I’m now using as just a picture frame is my SmartThings ‘offline mode’ device.
Update:
It seems Android cellular phone devices will work in offline mode as long as there isn’t any cellular service activated since I pulled out an old Android phone without cell service and the SmartThings app worked over WiFi in airplane mode.
Do you have more than one WiFi network? Ie an iot network and another network? If so I suspect the offline mode may only work on the same network because they are separate disjoint lans?
I did have a go but I think I was defeated by Android disabling the Wi-Fi because it had no internet at all, which seems to be regarded as a different condition to the Wi-fi being a bit pants. Too many things were being clever at the same time and I wasn’t one of them. I lost interest.
The bottom line is that it cant be called a seamless experience. It might be for some, and others might be able to make it one.
Disable it under Settings → Connections → Wi-Fi → ⋮ → Intelligent Wi-Fi → Switch to mobile data. The phone then stays on Wi-Fi and local devices remain reachable even without Internet.
That setting controls an automatic switch to mobile data when the Wi-Fi is slow or unstable. I have it disabled as I like to make up my own mind. The Wi-Fi was neither slow or unstable, it just didn’t have a connection to the internet. As soon as the lack of internet was detected the Wi-Fi was disconnected.
It wasn’t what I expected as mobile data implies internet, but it was what happened. There was a time when if there wasn’t any internet you were asked if you still wanted to connect or stay connected but that seems to have gone.
Maybe I need to try the Flight Mode with Wi-Fi combination. However since I don’t use the app for control it’s probably not something I should worry about too much.
I think they are working under the assumption that for most punters having access to local WiFi but not internet isn’t much use because most mobile apps browsers etc depend on internet connectivity.
None of that would be true however for those that wish to control smarthings devices during a Broadband outage. A bit of an an edge case, but a valid one nonetheless.
