one door sensor, one motion sensor, one smart button and a temperature sensor working…
the only ones reporting battery are door sensor (104% !!!) and the smart button (111%)…
the temperature sensor is reporting every minute… Took it outside and quickly dropped from 16C to 3C. At least it seams to be working… Accury i have no idea…
Thanks for all the experience shared and for the DH… Will order more and take advantage of this cheeeap great sensors
Top stuff. I’m in a similar position although the temp sensor seems temperamental. Doesn’t report in frequently. It’s been in a room right next to the hub for four hours that I know has changed temp yet no update???
yep… kinda temperamental… mine was outside for 10minutes and reported between 2.2 degrees and 3.3…
as far as i can see on in the log it’s reporting every 30 seconds… at least twice a minute…
bringing it back inside to see if it gets more stable. The humidity also changed a little outside, but a little less, from 59 to 66%.
What did you do to install it (I have the network ID and can ad the device, then the sensor is show, but no readings): did you install anything else: xuaomi plug or hub? how to get the temperature readings working?
From the app start "Add a thing"
Press and hold the button on the temp sensor until you get 3 flashes
When complete make sure that when you press the button the device give you two flashes on the LED, if not repeat step 2 until that happens.
Using the IDE look at the logs, not the live logging but the hub log (select hub, then select events)
Look for a catchall event at the same time as you pressed and held the button. You will see something like this:
catchall: 0104 0000 01 01 0100 00 B46D 00 04 115F 0A 01 01FF4231641000032814983900000000953900000000
Make a note of the device ID, in the case above it’s B46D (7th set of chars from the left)
Return to the IDE and manually add a device.
Enter the details and when asked select "Temperature Sensor and make sure you set the Zigbee and network id to the same value you found in step 6.
Finally received mine today! The smart button was a breeze to install, app found it within seconds of clicking. No battery report but I’ve read that should appear within time? Haven’t set the door sensor up yet but I can see me ordering quite a few of these!
