[OBSOLETE] Universal Ecobee Suite, Version 1.8.01
I upgraded from 1.7 to 1.8 yesterday, and I’m no longer able to add or remove sensors from comfort settings. I have a webcore piston that looks like:
The Ecobee Suite App and the device logs report that it succeeded:
The Ecobee Suite ST app shows that it’s been deleted:
But the Ecobee app disagrees:
Any ideas?
Lots of possible issues:
  • You can’t delete this sensor from Sleep
  • If you call two deletesSensor* back-to-back, one or both will fail. 1.8.** introduced updateSensorPrograms(activeList, inactiveList), plus addSensorToPrograms(List) and deleteSensorFromPrograms(List) so that you can make multiple changes in a single call to the Ecobee Cloud
Not sure what will happen, though, if you do deleteSensorFromPrograms(["Home", "Sleep"]), since you can’t remove it from Sleep.
Perhaps try adding another Sensor to Sleep by hand and then see if your WebCoRE piston works that way…
PS - ES will show completed before hearing back from the API. The Ecobee mobile apps and the physical thermostat won’t reflect the change until they are told about it by the Ecobee Cloud servers. But the Ecobee Mobile app doesn’t auto-refresh, so you may need to reload it.
Thanks for the response!
Sorry, I realize that my post was confusing. In my piston, I added another sensor to Sleep first, but that was failing, so the Ecobee app, as you noted, said I can’t remove the sensor from Sleep since it was the only one.
However, I found if I add a 5 second delay between each add/delete, it works. Not very elegant, but I can live with it.
Unfortunately, I don’t see commands for any of the functions you mention in Webcore:
Please let me know if there’s a better solution that the 5sec delay.
Thanks for your help!
You need to have WebCoRE reload the command interfaces for the sensor device…the new commands are there to solve exactly that problem…
Oh, an knowing the code, I would suggest a 7-second delay instead of 5 will be more reliable.
@storageanarchy, many thanks for all of your wonderful work. I am a new user of Smartthings in general and have enjoyed using your Ecobee Suite Manager app for the last month.
Although temperatures near Chicago haven’t risen to the point that I can see if it is working, I’m using your “Smart Mode, Programs & Setpoins” helper app for the specific purpose of turning off heat/AC and alerting me to open the windows whenever the temperature is in the “between” threshold. I’m using “SmartThings/TWC Weather for Home” to gather my outside temperature and dew point, and I have the temperature check frequency set for 5 minutes.
Initially, I was getting a text message every 5 minutes telling me that the outside temperature was “below” and it adjusted things accordingly. After about 70 of these text messages every 5 minutes, I stopped receiving them, so I thought perhaps it was a fluke. However, last night without any known changes by me, I started receiving text message notifications again every 5 minutes to my suprise. That lasted for about 7 hours and has now stopped. I attempted to turn on the “minimize settings text” option, but I’m not sure if that is related to my problem or not. What exactly does that toggle do?
I do want the outside temperature monitored every 5 minutes, but I don’t want to be texted about it unless the temperature crosses in or out of the “between” threshold so that I know to open or close the windows. What settings would permit that? I’m worried if I turn off all texting, then I won’t be alerted to open/close my windows which defeats my intended purpose.
Thanks again!
Hello. i am installing this suite for the first time. I followed all the steps in the “first time users installation” section of https://github.com/SANdood/Ecobee-Suite#install-mobile-smartthings and i am at the part where you are doingthe config of the app in the smart apps section on the device itself " Finalizing Installation on SmartThings Mobile" and everytime i try to authorize the “Ecobee Account Authorization” it will take my username and my password, i get a screen that i hit “accept” to allow the authorization i then get a screen that says "the connection could not be established! Click Done to return to the menu. i have tried from the classic app and the new app and same thing happens. its not my username and password for Ecobee cause it accepts that, it just wont let me authorize. any ideas??
OK, I suspect that you are using SMS notifications, and after 7 hours of sending a message every 5 minutes, you hit the daily max, and the messages stop. Then when SmartThings resets your count, you start getting messages again.
But the problem sounds odd - once it changes the mode to Heat (“below”), it shouldn’t repeat that until it wants to change the mode again. I’ll have to dig into it later today, as I have a meeting for the next few hours. I’ll get back to you.
Hmmm…sounds weird.
Have you double-checked that you enabled OAuth for Ecobee Suite Manager? That’s usually what causes issues, but the code should also inform you if OAuth isn’t properly enabled.
Next time you try to authenticate, first turn on Live Logging in the IDE. Once “Ecobee Suite Manager” appears in the top of the LL page, click on it, and then go try to authenticate. If you see ANY errors, copy/paste the surrounding Live Logging text and send that to me in a PM. I’ll have a look and see if I can figure out what is going on…
Many thanks! If it helps, I also noticed that all the text messages started at 9:30 p.m. and ended at 5:30 a.m. which is exactly the “schedule” that I have my ecobee set for the sleep schedule. Not sure if that means anything to you or not.
hello,
one step forward and then another roadblock. i figured it was 2FA that may be the issue so i disabled it in my app. i then went back to the suite manager app setup and BAM i was able to authorize the app. Now, however, after authorizing it goes back to the screen and it says “please tap save to save your credentials. then re-open the ecobee suite managerto continue the setup” and when i click save i get a red bar at the top “you are not authorized to perform the requested operation” and i am stopped again
UPDATE after uninstalling everything i started from scratch and finally got it installed. now if i turn 2FA back on will it break?
Hello! I recently swapped over to the new SmartThings app and notice on the Sensors it shows “Motion Detected” or “No Motion Detected” instead of just showing the temperature default. Is there a way to change the sensors to show temperature on the main SmartThings dashboard?
Thank you!
SmartThings has not made that possible, sorry.
I don’t know. Maybe another user can chime in, but I haven’t heard anything, good or bad.
Do you have the helper set to only adjust during the Sleep program?
I don’t believe so. In the help app, for the “Conditions: Perform Actions only when the Location Mode is” field, I left that blank since I didn’t want to limit the helper app from running at any time.
Ecobee Suite Manager Updated 24 April 2020 at 2:45pm EDT
This update is primarily cosmetic, and all of the SmartApps and Helpers have been updated (the Sensor and Thermostat drivers have not been changed).
I’m not going to list all of the version numbers anymore, but here are the primary non- cosmetic changes:
  • All Helpers that support Notifications
    • Updated to support the latest Echo Speaks Device release 3.6.2.0
  • All Helpers that change the thermostat’s program
    • Fixed type conversion issues for hourly holds
  • Ecobee Suite Manager, version 1.8.38
    • Cleaned up connection lost notification text
    • Started support for new “climates” enabled by the new Eco+ features (incomplete)
  • Ecobee Suite Smart Room, version 1.8.15
    • Doesn’t use Ecobee Sensor as a motion sensor, unless no other motion sensors are configured. This because of the inherent delay in active/inactive changes, which will cause a room to be prematurely activated.
  • Ecobee Suite Smart Switches, version 1.8.08
    • Fixes the logic to save and restore states (reverseActions())
Using Package Managers
I highly recommend that Ecobee Suite users make the small investment in time to setup one of the available automated package managers. This will significantly reduce the manual overhead of upgrading to new releases. Available options include:
  • SmartThings
    • SmartThings GitHub Integration is fully supported by the Ecobee Suite GitHub repository
    • SmartThings Community Installer - although this hasn’t changed in 2+ years, it remains a powerful tool for automating upgrades for a broad variety of applications and drivers.
  • Hubitat
    • The native “Import” capability should allow you to simply run through all of Ecobee Suite Apps & Drivers doing Import/Confirm/Save.
    • The recently released Hubitat Package Manager is really awesome, and I highly recommend it for everyone. It really will make managing your Ecobee Suite environment (and others) MUCH simpler!
These updates are recommended for all Ecobee Suite users
I have installed the app and the Ecobee site is asking for a 4 digit validation code. It appears to be operational. Did I miss a step during install that required a 4 digit validation code?
Great work with the app!
It sounds like you turned on Ecobee’s two-factor authentication…
It’s not set. When I log into the ecobee web portal and I click on my apps, the first screenshot comes up, I click add application and then it asks to validate your app.
