Sorry but there’s no error in logs. No idea why save fails.
@jbtibor created a poll to se if there is any interest for rboy looking into the new api.
Thx for your effort in the community
Hello,
I have vertical screens and velux roller shutters but both didn’t show up after logging in. So, I’ve added support for both io:VerticalExteriorAwningIOComponent and io:RollerShutterVeluxIOComponent.
In the Tahoma Link dashboard, I first looked in the setup http-request for the json response and found the qualified names for my screens and roller shutters were io:VerticalExteriorAwningIOComponent and io:RollerShutterVeluxIOComponent. I forked the initial code, and added a few lines of code to support both io:VerticalExteriorAwningIOComponent and io:RollerShutterVeluxIOComponent. Both will be treated as the initial io:RollerShutterWithLowSpeedManagementIOComponent. I have also made a pull request for this small addition.
I tested with two screens and two roller shutters and I can confirm all four of them show up in the list. After adding the screens and roller shutters, I am able to control them (up, down, level, stop, …).
The result of the code can be found:
https://github.com/vhjoeri/SmartThings/blob/master/Somfy/TaHoma/TaHomaBySomfy.SmartApp.groovy
Of course all credits to jbtibor for the huge work, I’ve just added a few lines. At least for my setup it is working now…
Thanks for all the work and for approving my pull request too @jbtibor. Only after trying @joerivh code my IO blinds showed up (I thought it didn’t work before). I was still missing my RTS blinds and managed to add that type too. Just added a debug statement and monitored the logs to find the right identifier.
jeanvancaloen
I also have an RTS blind which I cannot connect to smartthings the same way as the IO blinds. Could you please tell what exactly did you do to make it work? Thanks!
Following the readme you should be able to work it out. You can find it here https://github.com/jbtibor/SmartThings/tree/master/Somfy/TaHoma
Take care that you need to install another device handler for RTS blinds
Hope it helps
I also have some Velux equipment in my home. A Velux IO blind and a Velux IO roof window (Velux Skylight). Both show up in Tahoma together with my 3 Somfy RTS shutters. The 3 RTS shutters are discovered bij this great app, but my Velux devices (added via IO-Homecontrol) don’t show up, I’m afraid. Not even after Joeri’s code merge.
I get the following Live Logging when trying to discover my Tahoma devices:
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:25: debug SA 1.3.20180612: initialize()
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:25: debug SA 1.3.20180612: setDefaultValues()
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:25: debug SA 1.3.20180612: updateDevices(): rollerShuttersWithLowSpeedManagementIOComponent [:]
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:25: debug SA 1.3.20180612: updateDevices(): rawDeviceData [6b6cb272-33e3-4910-87d7-346a89d4c6fc.rts://1213…etc.(these are the RTS shutters, if I’m correct?!)
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:25: debug SA 1.3.20180612: updateDevices(): lightIOSystemSensors [:]
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:25: debug SA 1.3.20180612: getAuthorizationHeaderValue: Using cached token.
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:25: debug SA 1.3.20180612: [method:GET, uri:https://www.tahomalink.com/enduser-mobile-web/enduserAPI/, path:setup, headers:[Cookie:JSESSIONID=75F7CF8832E536DE42A397F26A53]]
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:25: debug SA 1.3.20180612: getAuthorizationHeaderValue()
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:24: debug SA 1.3.20180612: getRollerWithLowSpeedManagementIOComponentShutterNames()
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:24: debug SA 1.3.20180612: getRollerShutterNames()
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:24: debug SA 1.3.20180612: names [:]
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:24: debug SA 1.3.20180612: getSwitchNames()
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:24: debug SA 1.3.20180612: interiorRollerBlindNames [:]
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:24: debug SA 1.3.20180612: updateDevices(): rollerShuttersWithLowSpeedManagementIOComponent [:]
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:24: debug SA 1.3.20180612: updateDevices(): rollerShutters [6b6cb272-33e3-4910-87d7-346a89d4c6fc.rts://1213…etc.(these are the RTS shutters, if I’m correct?!)
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:23: debug SA 1.3.20180612: getAuthorizationHeaderValue: Authorizing with server.
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:24: debug SA 1.3.20180612: updateDevices(): interiorRollerBlinds [:]
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:24: debug SA 1.3.20180612: updateDevices(): lightIOSystemSensors [:]
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:24: debug SA 1.3.20180612: getAuthorizationHeaderValueCore(): authorizationHeaderValue JSESSIONID=75F7CF8832E536DE42A397F26A53
6b6cb272-33e3-4910-87d7-346a89d4c6fc 11:54:23: debug SA 1.3.20180612: settingsPage()
Could anyone help with discovering my Velux equipment?
Hello,
I would like to add some devices.
I have
- IO Protexial alarm with motion detectors, opening detectors
- IO orientable sun shade, IO temperature sensor, IO heating stuff
- RTS light stuff
- Legrand Netatmo: lights and outlets
@jbtibor, I’m interested if you could send me some advice how to capture things from chrome to add new devices.
Regards,
Ben.
I’m using https://www.tahomalink.com/enduser-mobile-web/externalAPI/json/getSetup to get installation information but I’m not able to find any link with your code for my switches for example.
Could someone help me how to find device type names from my configuration and make a link into a deviceHandler ?
Lobby for this to happen
@jbtibor Any chance you might want to port your code to Hubitat?
I migrated some months ago and really miss it
Sorry, this should be done by someone who has a Hubitat hub. It’s not that trivial, see this:
Unfortunately that is for the MyLink only.
Installing your integration on Hubitat fails on the setup because you can’t select the blinds, although the logs show they are listed correctly.
It’s a shame you don’t own a hubitat hub.
I believe it could be fixed by adjusting some of the methods using without anything major.
I tried it myself, but without success.
Hello, as of today 31 January, I seem to be having an issue with this SmartApp, which has been running very smoothly. Right now I am not able to control any shutters, in the IDE I get the following errors on any device:
error java.lang.reflect.UndeclaredThrowableException @line 118 (open)
error java.lang.reflect.UndeclaredThrowableException @line 82 (close)
Also in the SmartApp after tapping “next” on the first page (username/password) I am presented just with a blank screen. If I tap “next” I get the “we’re having trouble connecting” message.
I’ve re-entered my password, short of deleting and removing (I have 16 shutters and many automation I don’t want to lose), I’m not quite sure where to go. I can still control the shutters with Google Home/Assistant so at least it isn’t a Tahoma connection box issue.
It’s not an issue with the smart app nor the driver. looks like www.tahomalink.com certificate expired yesterday Jan 30th 2022 and they forgot/didn’t renew it.
Not sure if they are phasing out this tool or they just forgot to renew the certificate.
Ah OK that explains things. I sure hope they fix it this is the only integration with SmartThings that works solidly for Tahoma, at least in my experience. But with the eventual end of Groovy, I am probably going to be forced to look around.
Update: I found this thread. It appears Somfy is aware and working on it.
They just renewed the certificate. Just re-login in smartthings app and back in action.
