Yes, you can install as many instances of Smart Alarm as you want and they can be armed and disarmed independently. You just need to be careful if you use the same siren in several instances because the sirens are always turned off when Smart Alarm is reset.
Perfect, thanks!
Yeah I figured I would have to be careful and not “cross-trigger” either. I only plan to have the second one for the one Alert Zone and only text.
Thanks,
Scott
How do you uninstall this app? I accidentally made an extra entry version and it is empty, but i don’t see an uninstall button.
You can always remove it from the IDE https://graph.api.smartthings.com/ide/apps
Click on the “eye” icon to the left of the app, then click “Edit” button in the upper right corner, then click red “Delete” button.
Interesting thing happen last night. I just installed this yesterday so i have been able to test the night mode and leaving auto arming. I did test directly setting to away and guest for the two away and stay arms respectively. Night is also configured as a away mode. I have an UP24 band, I set it into sleep and that will set the house into night. But the system didn’t arm. So i laid there playing with setting back to home, back to night, back to home, back to away, restarting the app. Finally, the night triggered the arming. So, i am trying to figure out what happened
You can look at the event log in the IDE to see what exactly happened and when.
I enabled OAuth and enabled Rest with a Pin. I have it working where I can get status and arm the alarm with a URL in a web browser, but I cannot disable it. How do I enter the pin?
Thank you.
-Todd
You need to add your pin to the url: disarm/123456
or whatever.
Cameron - I have ST automatically set to night @ 11:59pm and good morning / home @ 5:30 am
Smart Alarm auto on for night and away, off for good morning / home
my UP24 band reliably sets ST to night when I press the button 9moon) and again in the morning when pressed again for good morning (sun) - my only issue ever has been when my phone blue tooth was turned off or my band was dead.
another thing I set up on my phone was to change the sound from the usual “ding” I got a text / push to a barking dog (my virtual watch dog) I know now when my phone “barks” Smart Alarm is armed or disarmed
also I do not sleep with my phone … it stays in the kitchen 30’+ away and down a flight of stairs
Dan T
Was just playing around with baldeagle072’s Push Notifier app and he made a quick change to make the Push Bullet popup on IOS much better.
Right now when you get a Push Bullet from SmartAlarm the popup you get just says “note:SmartThings”, no matter what, and you have to go into the Push Bullet app to see what the message is.
He changed it in his app to have the option to have the “message” displayed as the “title” so the "Alarm or Status will show on the popup message. This is the way it shows by default if using SMS but would be really cool if you could add that ability as well.
His code shows what change he made but I just don’t know how to change it on your app
Thanks,
Scott
If you are using @625alex’s device type, to nee to change this line of code (both times it comes up):
if (settings.pushbulletAlarm && settings.pushbullet) {
settings.pushbullet*.push(msg)
to
settings.pushbullet*.push(msg, msg)
or something similar. If you use just one argument, it sends just the message. If you send two arguments, it would be push(title, message). The first argument would show up as the title.
PERFECT!!! This works great!
I am not very savvy with ST but would love if someone would take a few minutes to walk me through the install of smartalarm. I will configure the app myself but am unsure how to install it. If possible I would also like some help setting up a tablet as a security panel in my home. Any and all help is appreciated.
A step-by-step installation guide is on Github:
https://github.com/statusbits/smartalarm
Hope it helps.
My SmartAlarm seems like it disappeared in the ST App but it’s still listed in the IDE under My SmartApps.
I’m on version 2.2.1 can I just replace this old code with your new code? Or should I delete and start over?
Thx
The current released version is shared as “Smart Alarm V2.2.5” i the IDE. You can replace your existing app without uninstalling. Just make sure after you “publish” it, open app properties in the mobile app and tap “Done” until it closes.
I was able to install Smart Alarm, actually have to say, once I figured out how to install, it’s really fairly simple. Thanks much for the app, it works as defined.
So, I do have one question… I have tried to goof with the code but not getting close. I would like to change the trigger to be based on a stream of events occurring. That is if living motion and Den motion are both triggered the turn on alarm. Or if Front Door open and Living motion are both triggered then turn on alarm.
So essentially I’m suggesting the zones could be 2 or more sensors are ALL true/active.
Any thoughts. Thanks much
I can understand your particular needs, however the problem is how to make it generic and intuitive for other users. It would require some kind of generic “rule builder” to logically AND and OR multiple sources. This was discussed many times before and SmartThings is supposedly “working on it”. I guess we’ll have to wait and see…
@geko I am only one of the few who is yet to install it… Too scared… BTW… Did you mail me that check of 30$.
Do you have any security system installed? With all the hi-tech gear you brag about on this board, you may be a prime target for the burglars.
Actually, I did figure out how to make the remote work - you just need to buy Vera for $99 to set it up. So, I suppose we’re even.
