Probably a SmartThings bug of some sort, but this entire system is headed for the scrap heap at some point in the future when Samsung finally makes the conversion to the new app and structure. So it’s not worth worring about it. However, this was very frustating for me and I’m quite sure for you. I’m pleased it is solved.
For example, in real contact sensor opens it has the option to add my arrival sensors (I have 4) but you can see in beep entry delay I can’t use them, not sure the real reason why but I think will be nice if you want to choose an arrival sensor to be more discrete when I’m sleeping… And the entry delay beep, it works with exit delay too? If not you should add it. Thanks.
I am not familiar with “Arrival Sensors” Suggest using Webcore for custom actions with these devices.
The Beep on entry delay is designed for a siren chirp as a warning. You are free to change the capability criteria in the source, as long as the target device has a beep cabability it will work.
All real keypads sound tones at exit and entry delay, they are not very loud (IMHO).
I understand what you want: sllence some sounds during user defined hours. Maybe sometime in the distant future, but not an option for now.
@arnb I was wondering is there a way with your app to get notifications when the system arms and disarms. I know this was possible with Smart Alarm but since I installed your app a few days ago I don’t get any notifications did I miss something? Any help on insight would be appreciated. BTW really great app.
For the SHM Delay app as a whole, notifications are shown in the phone app Notifications page. Intrusion alerts and door open alerts are based upon your delay profile settings. On my personal system I use Bigtalker with Lannouncer for voice status notifications, along with visuals from ActionTiles.
For the beta Simulated Keypad, onscreen status and lastpin accept or reject should be released soon.
Beta(zoid) release of the SHM Delay Simulated Keypad updated to display status: Accepted or Rejected of last pin entered, and Smarthings SHM Status and Mode.
Installation: Please Update from the beta repo
SHM Delay V2.0.8 Save and Publish
SHM Delay Simkypd Child V1.0.1 Save, do not publish
Beta release Jun 03, 2018 11:30AM EDT of the SHM Delay Simulated Keypad
Updated to display status: Accepted or Rejected of last pin entered, Smarthings SHM Status and Mode, Exit Delay, Entry Delay, Intrusion, and Panic. Also, when setting Away Exit Delay mode from a simulated keypad triggers Away Mode Exit Delay on all real keypads, including the keypad tones.
What could this be used for?
Giving access to your Smarthings system to a spouse, friend, child, dog walker, neighbor, sitter, etc without having to install the Smarthings App or any other software on their phone, Each user has a unique pin, that may include date and time restrictions.
Try out and setup your system with a “Simulated Keypad” before making the decision to purchase and install a real keypad.
SHM Delay V2.0.8 Save and Publish (Please reinstall, yesterday’s version was replaced)
Should you prefer running the simulated keypad from an Android app, it may be downloaded at https://www.arnb.org/keypad/keypad.apk You must allow Andoid to install apps from “Unknown Sources”. The app was generated using Phonegap using the same code used with the browser url. An IOS app is likely not going to be released due to the need to spend at minimum $100 to simply create the app.
