SHM Delay Version 2.0, How to convert from prior version
Enhancements and Changes
Smartapp includes full support for all Iris, Xfinity and Centralite keypads, User pin profiles, and SmartThings interactions. Lock Manager is no longer needed by SHM Delay when using a Keypad device.
Previous Smartapp settings and delay profiles are used by updated SmartApp, along with new global keypad settings and user profile information. This allows for an easy transition, and quick recovery in the unlikely event that a fallback is required.
SHM Delay now includes a keypad centric facility to maintain user pins that may include an optional schedule with easy date entry. User profile data is verified for errors, then displayed for verification prior to being saved.
Optimized, self contained code provides smoothe, reliable keypad operations with an easier learning curve.
Pin can execute a SHM Routine or Webcore Piston aka pin type.
Issues Notification log message when SHM Delay Modefix changes the SHM mode
Issues Notification log message when accepted pin was entered, with pin type and user name
Issues Keypad tones as follows:
Short beep - pin accepted (may issue a medium beep)
Medium beep - pin accepted but was not a user pin, or bad pin and bad pin count > 1
Long beep - pin rejected and bad pin count reached (always works)
How to Install
There are four (4) modules associated with the app:
- SHM Delay. Module should be Saved, Published, then Installed with the Smarthings app (must be done first)
- SHM Delay Child. Should be Saved, do not publish or Install.
- SHM Delay ModeFix Should be Saved, do not publish or install
SHM Delay Version 2.0, How to convert from Version 1
How to Install
SHM Delay User Should be Saved, do not publish or install. (New module added with Version 2) version
- SHM Delay User Should be Saved, do not publish or install. (New module added with Version 2) version
There are two ways to Install:
Install via the repository (preferred), add the following to the IDE Settings.
Owner: arnbme (in upper case that is ARNBME)
Branch: Version2
1 Click ‘Save’
2 When prior version of SHM Delay already installed via github : change the IDE source for SHM Delay, SHM Delay Child, and SHM modefix from Master to Version2 branch
3 In ‘My Smart Apps’ click 'Update from repo",
4 select the SHMDelay Version2 repository, then install and publish SHM_Delay (must be first)
5 install do not publish SHM_Delay Child, SHM_Delay ModeFix, SHM Delay User
6 (If not previously done) In the ST Phone APP install the SHM_Delay app -
Manually install by going to https://github.com/arnbme/SHMDelay/tree/Version2/smartapps/arnbme then copy the modules and install 'from code"
Prepare smartapp for use
- When using SHM Delay to control all Keypads
- Important In Ethayer’s Lock Manager app: Remove ALL keypad profiles.
- important In Lock Manager go to Automation->SmartApps->Lock Manager, Remove all Keypad Routines
- in SHM Delay edit Global Settings (scroll if it does not show)
- Set slider on to activate Total Keypad Control, then review all existing global settings and add Keypad information. Then Save
- Review existing Delay Profiles, then Save
- Create one or more User Pin Profiles
- Test your system.
- Lock Manager is no longer needed by SHM Delay for keypad control
- When not using SHM Delay to control any Keypads
- Review all preferrences and profiles.
- Test your system
Known issues
- Occasional strange system operation when creating a user profile. Ignores all input data or forces reentry of a field.
SHM Delay Release Thread There are two ways to Install:
Branch: Version2
1 Click ‘Save’
- Test your system.
- Test your system
Known issues
