[OBSOLETE] Moes 2 and 3 gang Zigbee wall switch ( cluster EF00)
That’s the procedure.
This was taken from here:
Yes thanks for this.
When I connect N & L and then Long Press the reset button - nothing happens.
I press and release the Reset button to get a Single Beep, and then Long Press the Rest Button to get the Di-Di(2 times).
Then release and Long press again and get Di-Di-Di-Di(4 beeps).
So the device is not doing as the instructions say or I am doing something different?
I cant get the device to beep sound continously…
HAs anyone else experienced this?
Hello @ygerlovin YouΒ΄re probably very busy, but think could help on this?
that one is SO hadfull here…
cheers!
Deleted… mistake
Are you referring to this switch ?
This have been added by @Mariano_Colmenarejo
Hi everyone,
I have several of these devices (2 gang):
My impression was that while one is just the module, and the other includes a wall switch, otherwise they are very similar, and should appear similar from ST perspective. The problem is that while the 2 gang module works fine with @ygerlovin 's β€œZigbee Multi Gang Switch [YG]”, the 2 gang wall switch doesn’t allow me to select any driver other than β€œZigbee Switch” from β€œSmartThings Drivers (Beta)”, which shows it as a single switch, not multi gang. @ygerlovin is there a chance you can add this device to your driver?
Btw, thank you for your work.
Alternatively, can someone point out a driver that can work with the multi gang wall switch?
Should work with Mariano drivers.
Try : zigbee-multi-switch-v4-childs
@dotan_shai thank you for the answer. I’ve installed the driver you mentioned, but it doesn’t appear in the list for the wall switch either.
Please install also:
ZigBee Thing MC
from same the same channel and switch to that driver. It won’t make it works but it will give the fingerprint of your device. @Mariano_Colmenarejo will be able to add it to his driver.
Done
Hi @Armen_Saghatelian
Added to this driver version
 Name         Zigbee Multi Switch and Child Mc
 Version      2022-12-30T13:57:19.776389639
- id: "TS0012/_TZ3000_s8r1qoyq"
    deviceLabel: TS0012 Switch
    manufacturer: _TZ3000_s8r1qoyq
    model: TS0012
    deviceProfileName: two-switch
Thanks a lot @Mariano_Colmenarejo @dotan_shai
It worked
