I went to use the pico today and it didn’t work. When I did the systemctl status lutron command, here is what I found:
Mar 13 02:05:00 raspberrypi2 node[377]: Device update recieved
Mar 13 02:05:00 raspberrypi2 node[377]: likely a manual change
Mar 13 02:05:00 raspberrypi2 node[377]: Received: ~OUTPUT,3,1,0.00
Mar 13 02:05:00 raspberrypi2 node[377]: Received: ~OUTPUT,5,1,0.00
Mar 13 11:27:02 raspberrypi2 node[377]: Received: shutting down the integration
Mar 13 11:27:02 raspberrypi2 node[377]: Disconnected from SmartBridgePro
I then rebooted the rapsberry pi and it started working again. But, here’s what the systemctl status lutronpro looks like now. Any suggestions what is happening?:
Mar 14 19:09:51 raspberrypi2 node[383]: Buffered data is proper json
Mar 14 19:09:51 raspberrypi2 node[383]: {“CommuniqueType”:“ReadResponse”,“Header”:{“MessageBodyType”:“OneZoneStatus”,“StatusCode”:"200 O
Mar 14 19:09:51 raspberrypi2 node[383]: true
Mar 14 19:09:51 raspberrypi2 node[383]: data in listenSSL
Mar 14 19:09:51 raspberrypi2 node[383]: Received: ~OUTPUT,5,1,100.00
Mar 14 19:09:51 raspberrypi2 node[383]: Device update recieved
Mar 14 19:09:51 raspberrypi2 node[383]: likely a manual change
