I’ve got the same issue in that I cannot discover bridge anymore, this happened a few days ago. I’m unable to detect bridge with ST at all with (re)connect, it works fine independently.
thanks for your response.
I tried your suggestions but there was no Ghost app that I could see on the IDE
I hope someone else can help us since ST support was not able to help me. I have 10 bulbs which is an expensive investment, hope someone can help.
Thanks again @infofiend
As far as I am aware its just an extended version of the official hue app. So tonight reluctantly I will uninstall the ReConnect app and try the official one and see if that helps. Hopefully ST support will help then if not.
Mine was working perfect then all of a sudden the scenes don’t work, check the discovery app and the bridge can’t be found. Bulbs can still be controlled though, something odd is going on
I spent the time to remove everything from my instance and rediscover them, all worked fine. Strange to what of happened but I would not be keen to do that again, took ages.
Wish there was an easy way to remove devices, ploughing through all smart apps, routines and removing each association then adding it all back again is a pain especially as your infrastructure gets bigger
I am using the factory connect app and a few days ago all of my lamps had
disappeared so everything was still in place but nothing was working with
the echo. the Hue app and other apps I use were all fine. I ran through the
discover process and let smartthings find the lamps again, enabled the
lamps I wanted to use, and everything was back to normal. This was during
the last events noted on the smartthings web site for some changes hey made
that had caused some apps to quit working. I’ve had this up and running for
over a year with 32 bulbs and no issues. I’m moving away from the echo and
using cubic directly with our smart lamps. so far so good… just waiting
on the cubic hardware to be released.
echo and hue has worked perfectly for me without ST. Added the scene handling on top with ST works well though in my opinion. Cubic looks interesting and looks to do somethings well but too much in its infancy for me
I have removed all my other hue related apps however i can add the hub and even detect the bulbs. My issue is when i go to add a bulb i get the message
“An Unexpected error Occurred”
I’m getting the same error, I just went back to the old app
Hi,
Just tinkering about with this great smartapp, and had some questions…
When creating a scene on the hue app. It mentions that you have to manually trigger the scene On and Off (in order to generate the hidden off scene). I managed to get this working as documented using the hue app version 1 (i.e. 1.12.2).
Using the API Debugger I was able to confirm the generated scenes i.e. " on 0" and " off 0".
Now I tried the exact same steps but using the hue app version 2 (2.3.0). After creating the scene, triggering it off and on I discovered that the hidden off scenes (off 0) was not generated?
I know the whole setup and management of scenes is rather different on the new hue app (2.3.0); as the creation of scenes can only be created at a room level (scenes assoicated to a room, rather than a selection of different lights).
Anyways, my question is…does the Hue (Re)Connect work with the new hue app (2.3.0) in setting up scenes?
As I was unable to get the hidden off scene (off 0) generated? Then result meant that I could only turn the scene on, but could not turn the scene off.
The other question…I noticed there are some cool new features - ColourLoop On and Blink. Any further info on these?
When I managed to get a scene working on ST (using the old Hue App), the Blink button is available but doesn’t seem to function? Is that suppose to be the case?
Many thanks,
Hung
What does it mean in IDE when some of the device handlers appear in Brown text?
My hub was found and so were my lights. But scenes are MIA.
There seems to be something wrong getting group information
Very 5mins my kitchen light group has this in the log
e647f127-33ff-4c14-93c1-4d8b4b0c7ecf 11:15:09 AM: debug parse() - [name:saturation, value:35, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) saturation is 35]
e647f127-33ff-4c14-93c1-4d8b4b0c7ecf 11:15:09 AM: debug parse() - [name:hue, value:13, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) hue is 13]
e647f127-33ff-4c14-93c1-4d8b4b0c7ecf 11:15:09 AM: debug parse() - [name:color, value:#AC9852, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) color is #AC9852]
e647f127-33ff-4c14-93c1-4d8b4b0c7ecf 11:15:09 AM: debug parse() - [name:level, value:80, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) level is 80]
e647f127-33ff-4c14-93c1-4d8b4b0c7ecf 11:15:09 AM: debug parse() - [name:switch, value:off, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) switch is off]
But no other groups do it and I have 10 other groups
On the bridge im getting this every 5 mins
de7acc1d-b12b-4496-9c69-8435a438b073 11:35:08 AM: error java.lang.NullPointerException: Cannot get property ‘deviceNetworkId’ on null object @ line 809
I have fixed the problem new groups now appear and logs now appear this code also includes the following HTTP headers fix https://github.com/SmartThingsCommunity/SmartThingsPublic/pull/1264
Hhhmmm, I can still not see scenes. I went to a room in the Hue app(New) and started then shut off a scene about 5 times in a row. I also create a new Scene called “On 0” and turned it on and off 5 times.
Still no luck.
Any help would be greatly appreciated.
I’m confused by your post need more information, screenshots and check the logs on the IDE
Here are some screenshots and logs. Please let me know if you need anything else.
Log 1
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:41 PM: debug Response Body: {“20”:{“state”:{“on”:false,“bri”:25,“hue”:14988,“sat”:141,“effect”:“none”,“xy”:[0.4575,0.4101],“ct”:365,“alert”:“none”,“colormode”:“xy”,“reachable”:true},“type”:“Extended color light”,“name”:“Living Room A”,“modelid”:“LCT001”,“manufacturername”:“Philips”,“uniqueid”:“00:17:88:01:00:b6:b0:25-0b”,“swversion”:“5.23.1.13452”},“21”:{“state”:{“on”:false,“bri”:25,“hue”:14988,“sat”:141,“effect”:“none”,“xy”:[0.4575,0.4101],“ct”:365,“alert”:“none”,“colormode”:“xy”,“reachable”:true},“type”:“Extended color light”,“name”:“Living room B”,“modelid”:“LCT001”,“manufacturername”:“Philips”,“uniqueid”:“00:17:88:01:00:b6:9a:e1-0b”,“swversion”:“5.23.1.13452”},“22”:{“state”:{“on”:false,“bri”:254,“hue”:15338,“sat”:121,“effect”:“none”,“xy”:[0.4448,0.4066],“ct”:343,“alert”:“none”,“colormode”:“xy”,“reachable”:true},“type”:“Extended color light”,“name”:“Bedroom A”,“modelid”:“LCT001”,“manufacturername”:“Philips”,“uniqueid”:“00:17:88:01:00:f8:dc:f6-0b”,“swversion”:“5.23.1.13452”},“23”:{“state”:{“on”:false,“bri”:254,“hue”:25712,“sat”…[TRUNCATED]
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:41 PM: debug getChildDevices(false), children=19
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:42 PM: trace Host: 192.168.7.35:80 - 192.168.7.35:80
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:41 PM: debug Device (00178810585E) was already found in state with ip = 192.168.7.35:80.
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:41 PM: trace [uuid:2f402f80-da50-11e1-9b23-00178810585e:[lastActivity:1474482947319, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178810585e, verified:true, name:Philips hue (192.168.7.35), networkAddress:C0A80723, ssdpNTS:null, serialNumber:00178810585e, deviceAddress:0050, mac:00178810585E, devicetype:04, hub:3005ad1a-e334-49c0-b6b7-668f2d60a96f, ssdpPath:/description.xml, ssdpTerm:urn:schemas-upnp-org:device:basic:1, stringCount:04]]
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:41 PM: trace SSDP DISCOVERY EVENTS
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:41 PM: trace Location: devicetype:04, mac:00178810585E, networkAddress:C0A80723, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178810585e, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:41 PM: trace NON-HUE EVENT devicetype:04, mac:00178810585E, networkAddress:C0A80723, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178810585e, ssdpTerm:uuid:2f402f80-da50-11e1-9b23-00178810585e, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:41 PM: trace Location: devicetype:04, mac:00178810585E, networkAddress:C0A80723, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178810585e, ssdpTerm:uuid:2f402f80-da50-11e1-9b23-00178810585e, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:41 PM: trace NON-HUE EVENT devicetype:04, mac:00178810585E, networkAddress:C0A80723, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178810585e::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:41 PM: trace Location: devicetype:04, mac:00178810585E, networkAddress:C0A80723, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178810585e::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace NON-HUE EVENT devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:service:WANIPConnection:1, ssdpTerm:urn:schemas-upnp-org:service:WANIPConnection:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Location: devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:service:WANIPConnection:1, ssdpTerm:urn:schemas-upnp-org:service:WANIPConnection:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Host: 192.168.7.35:80 - 192.168.7.35:80
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: debug Device (00178810585E) was already found in state with ip = 192.168.7.35:80.
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace [uuid:2f402f80-da50-11e1-9b23-00178810585e:[lastActivity:1474482947319, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178810585e, verified:true, name:Philips hue (192.168.7.35), networkAddress:C0A80723, ssdpNTS:null, serialNumber:00178810585e, deviceAddress:0050, mac:00178810585E, devicetype:04, hub:3005ad1a-e334-49c0-b6b7-668f2d60a96f, ssdpPath:/description.xml, ssdpTerm:urn:schemas-upnp-org:device:basic:1, stringCount:04]]
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace SSDP DISCOVERY EVENTS
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Location: devicetype:04, mac:00178810585E, networkAddress:C0A80723, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178810585e, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace NON-HUE EVENT devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:service:Layer3Forwarding:1, ssdpTerm:urn:schemas-upnp-org:service:Layer3Forwarding:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Location: devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:service:Layer3Forwarding:1, ssdpTerm:urn:schemas-upnp-org:service:Layer3Forwarding:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace NON-HUE EVENT devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:device:WANDevice:1, ssdpTerm:urn:schemas-upnp-org:device:WANDevice:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Location: devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:device:WANDevice:1, ssdpTerm:urn:schemas-upnp-org:device:WANDevice:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace NON-HUE EVENT devicetype:04, mac:00178810585E, networkAddress:C0A80723, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178810585e::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Location: devicetype:04, mac:00178810585E, networkAddress:C0A80723, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178810585e::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace NON-HUE EVENT devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:device:InternetGatewayDevice:1, ssdpTerm:urn:schemas-upnp-org:device:InternetGatewayDevice:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Location: devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:device:InternetGatewayDevice:1, ssdpTerm:urn:schemas-upnp-org:device:InternetGatewayDevice:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace NON-HUE EVENT devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:device:WANConnectionDevice:1, ssdpTerm:urn:schemas-upnp-org:device:WANConnectionDevice:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Location: devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:device:WANConnectionDevice:1, ssdpTerm:urn:schemas-upnp-org:device:WANConnectionDevice:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace NON-HUE EVENT devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:service:WANCommonInterfaceConfig:1, ssdpTerm:urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Location: devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf:schemas-upnp-org:service:WANCommonInterfaceConfig:1, ssdpTerm:urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace NON-HUE EVENT devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf, ssdpTerm:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Location: devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf, ssdpTerm:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace NON-HUE EVENT devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Location: devicetype:04, mac:1422DB0AB10D, networkAddress:C0A80701, deviceAddress:076C, stringCount:04, ssdpPath:/igd.xml, ssdpUSN:uuid:fcdb9233-a63f-41da-b42c-7cfeb99c8adf::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: debug GET: /api/3lMtNaQPBFwHaGvKzofsIpUBVZrWlIroBZ-s3UfF/groups/
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:40 PM: trace Bridge: 00178810585E - Host: 192.168.7.35:80
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:38 PM: debug CONVERT LIST
1bfb225a-1001-40b0-ba87-b351018ace50 1:37:38 PM: trace Doing Hue Device Sync
Log 2
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:31 PM: debug Entered BulbsDiscovered
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:30 PM: trace Adding items to state…
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:29 PM: debug getChildDevices(false), children=19
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:30 PM: debug Its a scene
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:29 PM: debug Its a scene
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:29 PM: trace Adding items to state…
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:29 PM: debug Response Body: {“YSzazjkcVLExEyC”:{“name”:“Tropical twilight”,“lights”:[“22”,“29”,“35”],“owner”:“BVI6ub9sFQeymr-xkxtezGCUq81CsvLRGTC7BS1U”,“recycle”:false,“locked”:false,“appdata”:{“version”:1,“data”:“CXxV5_r04_d16”},“picture”:"",“lastupdated”:“2016-09-18T21:03:06”,“version”:2},“xGpcGr3QDNPF4xd”:{“name”:“Arctic aurora”,“lights”:[“22”,“29”,“35”],“owner”:“BVI6ub9sFQeymr-xkxtezGCUq81CsvLRGTC7BS1U”,“recycle”:false,“locked”:false,“appdata”:{“version”:1,“data”:“5PoLd_r04_d17”},“picture”:"",“lastupdated”:“2016-09-18T21:03:08”,“version”:2},“uob-1UzG6yLDf8S”:{“name”:“Savanna sunset”,“lights”:[“22”,“29”,“35”],“owner”:“BVI6ub9sFQeymr-xkxtezGCUq81CsvLRGTC7BS1U”,“recycle”:false,“locked”:false,“appdata”:{“version”:1,“data”:“Y9Mz4_r04_d15”},“picture”:"",“lastupdated”:“2016-09-18T21:03:10”,“version”:2},“PKEV5WXm-ol2vSs”:{“name”:“Spring blossom”,“lights”:[“22”,“29”,“35”],“owner”:“BVI6ub9sFQeymr-xkxtezGCUq81CsvLRGTC7BS1U”,“recycle”:false,“locked”:false,“appdata”:{“version”:1,“data”:“I9NHA_r04_d18”},“picture”:"",“lastupdated”:"2016-09-…[TRUNCATED]
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:28 PM: trace Adding Bedroom B to bulb list
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:28 PM: trace Adding Bathroom B to bulb list
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:28 PM: trace Adding Bathroom A to bulb list
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:28 PM: trace Adding Kitchen A to bulb list
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:28 PM: trace Adding Bedroom A to bulb list
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:28 PM: trace Adding Bedroom C to bulb list
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:28 PM: trace Adding Front Door to bulb list
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:28 PM: trace Adding Living Room A to bulb list
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:28 PM: trace Adding Living room B to bulb list
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:28 PM: debug Entered BulbsDiscovered
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:24 PM: debug Entered BulbsDiscovered
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:24 PM: trace Adding Office A to bulb list
1bfb225a-1001-40b0-ba87-b351018ace50 1:39:24 PM: trace Adding Living Room A to bulb list
have you added all the device handlers? https://github.com/CyrilPeponnet/smartthings/tree/master/smartapp/HueConnect/HueDevices
Are you using the code from here
https://raw.githubusercontent.com/CyrilPeponnet/smartthings/master/smartapp/HueConnect/HueConnect.groovy
or the code I posted yesterday?
Here are my device handlers
And I am using the code you put up yesterday.
I dont understand why you have different colours can I see a screenshot of the whole page
Found out what the brown links mean
Brown
Indicates that the SmartApp or device handler is unattached to the repository version. Typically this happens when a new SmartApp or device handler is created from a template, and the name or namespace hasn’t been changed. If you update from the repo without changing the name or namespace, the IDE version will be replaced with the repo version. Typically in this case you would change the name and namespace to be unique for your code.
