Hi
I got it working, thank you
Is it correct that the Edge-driver does not show up as a Device Handler?
Question: I see on the frontpage of the device itself, there are the nice 4 buttons, to progam for when pushed and held.
How do I program the dimmer-function-buttons?
When pushing button 2 (which is for turn the light level up), how do I program it to encrease the light level?
And another question
As in the Hue app, you can program what should happen after you press button 1 once, twice, third and forth time, with different color schemes.
Can that be done in ST and how then?
I have several Hue dimmer switches connected with this edge driver for almost 3 months, and my devices are still online. Health checking is pretty OK for this one.
I have just changed from DTH to Edge for my seven Hue Dimmers. I will let you know what the effects are.
Interesting fact: I forgot to uninstall the cloud handler before installing the edge driver, but it overwrote and replaced it anyway. Everything works.
EDIT: Though it’s not the case, but finally to use local driver I’ve had to delete and re-connect it.
After a few days of using the edge driver, I can say that two of the four dimmers connected in this way regularly drop out of the system and stop working. In addition to these four connected via edge I have three more connected via cloud, in the “old” way.
Could this affect the operation of the locally connected ones?
