I’m so close! I keep taking all these baby steps. That worked, I already tried that prior to that last post, I’m wondering if it was that I enabled OAUTH in the api page this time. It worked, and generated this: ( I did the xxxxx with this post)
Is the next step that I should be able to see the ST lights (the ones I checked in the JSONAPI smartapp) in the EVE app, and then they will work? Still can’t get Siri to find anything.
I did the above, but still don’t see anything in EVE or Insteon other than the accessory called “Homebridge”. Should I see the indivual lights within EVE? The homebridge terminal session on ubuntu looks normail with Requests, responses, keepalives, etc…
I’ve got to be one small step away from this working… Thanks so much for the help.
I don’t need to paste the output of the debug to config.json, do I?
Hi, I am a smart things UK user and i am trying to set up homebridge. When I add the smart app and then I go into the Config section, instead of seeing the config, it shows me: HTTP Status 500 - Cannot get property “authentication” on null object. Could you please help me.
I had the same, for me it was either Power cycling the phone, or enabling OAuth in the smartapp via the api smartthings page. I can’t remember which. I think it was the power cycling the phone that did it.
Man, I can’t believe I can’t get this to work. I’ve reversed the order of the config.json, in case that mattered. With each tweak, I am restarting the server, and deleting/re-adding the accessory in the EVE app. No matter what I do, none of my switches will show up. This is soooo frustrating.
What I mean by this - I now remember - logout and login to iCloud on the phone under settings. I also re-did the keychain, it might be default turned off when you logout/login to iCloud.
*** WARNING *** The program ‘nodejs’ uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs
*** WARNING *** The program ‘nodejs’ called ‘DNSServiceRegister()’ which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs&f=DNSServiceRegister
Starting HomeBridge server…
What does the JSON generation debug look like? Maybe post that? The Warnings are EXACTLY like the output I see. I doubt it is the switch brand, but what are you adding in the SmartApp? I have 1 Linear Switch (which I hate), 1 Leviton dimmer, 2 Leviton switches, 2 GE dimmers, 18 GE switches, 2 Dragon Tech switches, 1 Dry Contact Switch, 2 Wink bulbs. No issues.
Unfortunately, I am not an expert; I just got it to work.
My son, who worked on this with me suggested as a “last ditch effort” to:
Unpair the Eve app
Do a fresh compile/install on your PI
(We did that a couple of times)
