Hi capota, I’ve just seen that two states might not be defined properly, as the next state of opening is defined as closing, and next state of closing, is defined as opening. Shouldn’t be opening -> open, and closing -> closed?
This is first device handler code that I see and edit, so my understanding about it is quite limited, but it might work.
Try attached code and let me know if helps, just two lines changed in bold:
metadata {
definition (name: “Fibaro Persianas Custom”, namespace: “julienbachmann”, author: “Julien Bachmann”) {
capability "Sensor"
capability "Actuator"
capability "Switch"
capability “Switch Level"
capability “Polling"
capability “Power Meter"
capability “Energy Meter"
capability “Refresh"
capability “Configuration"
attribute “openCloseStatus”, “enum”, [“open”, “middle”, “close”]
attribute “syncStatus”, “enum”, [“syncing”, “synced”]
command “open"
command “close"
command “sync"
fingerprint inClusters: “0x26,0x32”
tiles(scale: 2) {
multiAttributeTile(name:“mainTitle”, type:“generic”, width:6, height:4, canChangeIcon: true) {
tileAttribute(“device.openCloseStatus”, key: “PRIMARY_CONTROL”) {
attributeState “open”, label:‘Open’, backgroundColor:”#ffa81e”, action: “switch.off”, nextState: “closing"
attributeState “middle”, label:‘Middle’, backgroundColor:”#d45614”, action: “switch.on”, nextState: “opening"
attributeState “close”, label:‘Closed’, backgroundColor:”#00a0dc”, action: “switch.on”, nextState: “opening"
attributeState “opening”, label:‘Opening’, backgroundColor:"#ffa81e", nextState: "open"
attributeState “closing”, label:‘Closing’, backgroundColor:"#00a0dc", nextState: “close”
tileAttribute(“device.level”, key: “SLIDER_CONTROL”) {
attributeState “level”, action:“switch level.setLevel”, defaultState: true, icon:“st.Home.home9”
valueTile(“power”, “device.power”, width: 2, height: 2) {
state “default”, label:’${currentValue} W’
valueTile(“energy”, “device.energy”, width: 2, height: 2) {
state “default”, label:’${currentValue} kWh’
standardTile(“refresh”, “device.switch”, width: 2, height: 2, inactiveLabel: false, decoration: “flat”) {
state “default”, label:“Refresh”, action:“refresh.refresh”, icon:“st.secondary.refresh-icon”
standardTile(name: “calibrate”, width: 2, height: 2, decoration: “flat”) {
state “default”, action:“configuration.configure”, label:“Calibrate”, backgroundColor:”#0000a8”
standardTile(“sync”, “device.syncStatus”, width: 2, height: 2, inactiveLabel: false, decoration: “flat”) {
state “default”, action:“sync” , label:“Sync”, backgroundColor:”#00a800"
state “synced”, action:“sync” , label:“Sync”, backgroundColor:”#00a800"
state “syncing” , label:“Syncing”, backgroundColor:”#a8a800”
main([“mainTitle”])
details([“mainTitle”, “power”, “energy”, “refresh”, “calibrate”, “sync”])
preferences {
input name: “invert”, type: “bool”, title: “Invert up/down”, description: "Invert up and down actions"
input name: “openOffset”, type: “decimal”, title: “Open offset”, description: "The percentage from which shutter is displayerd as open"
input name: “closeOffset”, type: “decimal”, title: “Close offset”, description: "The percentage from which shutter is displayerd as close"
input name: “percentageOffset”, type: “decimal”, title: “Percentage offset”, description: "The percentage offset to correct level"
section {
input (
type: “paragraph”,
element: “paragraph”,
title: “DEVICE PARAMETERS:”,
description: "Device parameters are used to customise the physical device. " +
“Refer to the product documentation for a full description of each parameter.”
getParamsMd().findAll( {!it.readonly} ).each { // Exclude readonly parameters.
def lb = (it.description.length() > 0) ? “\n” : ""
switch(it.type) {
case “number”:
input (
title: “#${it.id}: ${it.name}: \n” + it.description + lb +“Default Value: ${it.defaultValue}”,
type: it.type,
range: it.range,
required: it.required
break
case “enum”:
input (
title: “#${it.id}: ${it.name}: \n” + it.description + lb + “Default Value: ${it.defaultValue}”,
type: it.type,
options: it.options,
break
} // section
log.debug(“parse ${description}”)
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x26: 3, 0x70: 1, 0x32:3])
if (cmd) {
result = zwaveEvent(cmd)
if (result) {
log.debug(“Dispatch events ${result}”)
} else {
log.debug(“Couldn’t zwave.parse ${description}”)
result
def correctLevel(value) {
def result = value
if (value == “off”) {
result = 0;
if (value == “on” ) {
result = 100;
if (invert) {
result = 100 - result
return result
def createOpenCloseStatusEvent(value) {
def theOpenCloseStatus = “middle"
if (value >= (openOffset ?: 95)) {
theOpenCloseStatus = “open”
if (value <= (closeOffset ?: 5)) {
theOpenCloseStatus = “close”
return createEvent(name: “openCloseStatus”, value: theOpenCloseStatus, isStateChange: true)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
logger.debug(“basic report ${cmd}”)
def result = []
if (cmd.value != null) {
def level = correctLevel(cmd.value)
result << createEvent(name: “level”, value: level, unit: “%”, isStateChange: true)
result << createOpenCloseStatusEvent(level)
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
logger.debug(“basic set ${cmd}”)
def result = []
if (cmd.value) {
return result
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv3.SwitchMultilevelStopLevelChange cmd) {
log.debug(“switch stop event ${cmd}”)
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv3.SwitchMultilevelReport cmd) {
log.debug(“switch multi level report ${cmd.value}”)
def result = []
return result
log.debug(“other event ${cmd}”)
def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd) {
if (cmd.meterType == 1) {
if (cmd.scale == 0) {
return createEvent(name: “energy”, value: cmd.scaledMeterValue, unit: “kWh”)
} else if (cmd.scale == 1) {
return createEvent(name: “energy”, value: cmd.scaledMeterValue, unit: “kVAh”)
} else if (cmd.scale == 2) {
return createEvent(name: “power”, value: Math.round(cmd.scaledMeterValue), unit: “W”)
} else {
return createEvent(name: “electric”, value: cmd.scaledMeterValue, unit: [“pulses”, “V”, “A”, “R/Z”, “”][cmd.scale - 3])
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
log.debug(“zwaveEvent(): Configuration Report received: ${cmd}”)
def updated() {
setSynced();
def on() {
open()
def off() {
close()
def open() {
setLevel(100)
def close() {
setLevel(0)
def poll() {
delayBetween([
zwave.meterV2.meterGet(scale: 0).format(),
zwave.meterV2.meterGet(scale: 2).format(),
], 1000)
def refresh() {
log.debug(“refresh”)
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.switchMultilevelV3.switchMultilevelGet().format(),
], 500)
def setLevel(level) {
if (invert) {
level = 100 - level
if(level > 99) level = 99
if (level <= (openOffset ?: 95) && level >= (closeOffset ?: 5)) {
level = level - (percentageOffset ?: 0)
log.debug(“set level ${level}”)
delayBetween([
zwave.basicV1.basicSet(value: level).format(),
zwave.switchMultilevelV1.switchMultilevelGet().format()
], 10000)
def configure() {
log.debug(“configure roller shutter”)
delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: 29, size: 1, scaledConfigurationValue: 1).format(), // start calibration
zwave.switchMultilevelV1.switchMultilevelGet().format(),
], 500)
def sync() {
log.debug(“sync roller shutter”)
def cmds = []
sendEvent(name: “syncStatus”, value: “syncing”, isStateChange: true)
if (settings.“configParam${it.id}” != null) {
cmds << zwave.configurationV1.configurationSet(parameterNumber: it.id, size: it.size, scaledConfigurationValue: settings.“configParam${it.id}”.toInteger()).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: it.id).format()
log.debug(“send cmds ${cmds}”)
runIn(0.5 * cmds.size(), setSynced)
delayBetween(cmds, 500)
def setSynced() {
log.debug(“Synced”)
sendEvent(name: “syncStatus”, value: “synced”, isStateChange: true)
private getParamsMd() {
return [
[id: 3, size: 1, type: “number”, range: “0…1”, defaultValue: 0, required: false, readonly: false,
description: “0 – Blind position reports sent to the main controller using Z-Wave Command Class.\n” +
“1 - Blind position reports sent to the main controller using Fibar Command Class.\n” +
“Parameters value shoud be set to 1 if the module operates in Venetian Blind mode.”],
[id: 10, size: 1, type: “number”, range: “0…4”, defaultValue: 0, required: false, readonly: false,
name: “Roller Shutter operating modes”,
description: “0 - Roller Blind Mode, without positioning\n” +
“1 - Roller Blind Mode, with positioning\n” +
“2 - Venetian Blind Mode, with positioning\n” +
“3 - Gate Mode, without positioning\n” +
“4 - Gate Mode, with positioning”],
[id: 12, size:2, type: “number”, range: “0…65535”, defaultValue: 0, required: false, readonly: false,
name: “Time of full turn of the slat”,
description: “In Venetian Blind mode (parameter 10 set to 2) the parameter determines time of full turn of the slats.\n” +
“In Gate Mode (parameter 10 set to 3 or 4) the parameter defines the COUNTDOWN time, i.e. the time period after which an open gate starts closing. In any other operating mode the parameter value is irrelevant.\n” +
“Value of 0 means the gate will not close automatically.\n” +
“Available settings: 0-65535 (0 - 655,35s)\n” +
“Default setting: 150 (1,5 s)”],
[id: 13, size:1, type: “number”, range: “0…2”, defaultValue: 0, required: false, readonly: false,
name: “Set slats back to previous position”,
description: “In Venetian Blind Mode (parameter 10 set to 2) the parameter influences slats positioning in various situations. In any other operating mode the parameter value is irrelevant.\n” +
“0 - Slats return to previously set position only in case of the main controller operation\n” +
“1 - Slats return to previously set position in case of the main controller operation, momentary switch operation, or when the limit switch is reached.\n” +
“2 - Slats return to previously set position in case of the main controller operation, momentary switch operation, when the limit switch is reached or after " +
” receiving a “STOP” control frame (Switch Multilevel Stop).”],
[id: 14, size:1, type: “number”, range: “0…2”, defaultValue: 0, required: false, readonly: false,
description: “The parameter settings are relevant for Roller Blind Mode and Venetian Blind Mode (parameter 10 set to 0, 1, 2).\n” +
“0 - Momentary switches\n” +
“1 - Toggle switches\n” +
“2 - Single, momentary switch. (The switch should be connected to S1 terminal)”],
[id: 18, size:1, type: “number”, range: “0…255”, defaultValue: 0, required: false, readonly: false,
name: “Motor operation detection.”,
description: “Power threshold to be interpreted as reaching a limit switch. \n” +
“Available settings: 0 - 255 (1-255 W)\n” +
“The value of 0 means reaching a limit switch will not be detected \n” +
“Default setting: 10 (10W).”],
[id: 22, size:2, type: “number”, range: “0…65535”, defaultValue: 0, required: false, readonly: false,
name: “Motor operation time.”,
description: “Time period for the motor to continue operation. \n” +
“Available settings: 0 – 65535 (0 – 65535s)\n” +
“The value of 0 means the function is disabled.\n” +
“Default setting: 240 (240s. – 4 minutes)”],
[id: 30, size:1, type: “number”, range: “0…2”, defaultValue: 0, required: false, readonly: false,
name: “Response to general alarm”,
description: “0 - No reaction.\n” +
“1 - Open blind.\n” +
“2 - Close blind.”],
[id: 31, size:1, type: “number”, range: “0…2”, defaultValue: 0, required: false, readonly: false,
name: “Response to flooding alarm”,
[id: 32, size:1, type: “number”, range: “0…2”, defaultValue: 0, required: false, readonly: false,
name: “Response to smoke, CO or CO2 alarm”,
[id: 33, size:1, type: “number”, range: “0…2”, defaultValue: 0, required: false, readonly: false,
name: “Response to temperature alarm”,
[id: 35, size:1, type: “number”, range: “0…2”, defaultValue: 0, required: false, readonly: false,
name: “Managing slats in response to alarm.”,
description: “0 - Do not change slats position - slats return to the last set position\n” +
“1 - Set slats to their extreme position”]
