That code is in the handler for the RSM2-Plus (minus the exception I mentioned). The handler has been thouroughly tested with the firmware versions I have listed.
I think you may have been using the handler for the regular RSM2 or an older version of the handler for the RSM2-Plus.
preferences {
input description: “Once you change values on this page, the corner of the "configuration" icon will change orange until all configuration parameters are updated.”, title: “Settings”, displayDuringSetup: false, type: “paragraph”, element: “paragraph”
generate_preferences(configuration_model())
// This will capture any commands not handled by other instances of zwaveEvent
// and is recommended for development so you can see every command the device sends
logging(“Unhandled Event: ${cmd}”, 2)
def integer2Cmd(value, size) {
switch(size) {
case 1:
[value]
break
case 2:
def short value1 = value & 0xFF
def short value2 = (value >> 8) & 0xFF
[value2, value1]
break
case 3:
def short value3 = (value >> 16) & 0xFF
[value3, value2, value1]
break
case 4:
def short value4 = (value >> 24) & 0xFF
[value4, value3, value2, value1]
break
def zwaveEvent(physicalgraph.zwave.commands.configurationv2.ConfigurationReport cmd) {
update_current_properties(cmd)
logging(“${device.displayName} parameter ‘${cmd.parameterNumber}’ with a byte size of ‘${cmd.size}’ is set to ‘${cmd2Integer(cmd.configurationValue)}’”, 2)
Yep, the configure method (before your changes) calls this block of code. It determines whether you are using the latest 5.11 firmware or not and creates the necessary associations. The changes you are mentioning will not work with the 5.11 version of the switch. You are @ing people that were using the RSM2 device handler on the RSM2-Plus (back in January - which I did not have at the time and had not created a handler for it).
Don’t get me wrong, I’m glad that you got it working, but I’m just saying I don’t think people need to make any additions to the handler as is. It may have been that the configure method didn’t get called when you had my handler installed, or some other error.
thanks for your help. The only thing I can think of is maybe I tried the original RSM code originally then copied and pasted the updated plus code and didn’t hit save… Anyway, it looks like you are saying use
I have read through this thread three times and am still not sure how to solve my problem. My RSM2, which I installed around two years ago, so I assume it is version 1, is not working as I would like. As of a few months ago, I can no longer turn off one of the lights without using the wall switch. I rarely use this light, so maybe it was longer ago than a couple/few months.
Today I would like to try the software presented here by Eric M, but am confused. I want to remove the existing software I’m using (and I am not positive of exactly how - I am using a “Z-Wave Device Multichannel”), and add Eric’s software, but I am not sure what the steps are to do that. Did I miss a reply here that provides step by step directions on setting up this software once the Enerwave has already been paired?
I’ve got a RSM2-Plus installed, connected in the bathroom to a light (Load 1) and an exhaust fan (Load 2).
The light is a CFL and goes on/off with no issues, I can even set motion triggers and it works. However the fan is very “sometime-ish”. It comes on somethings using the ST app, sometimes it doesn’t switch off.
When I turn on the fan, I can see the light flickering and the relay crackles for about a second (or a bit longer than usual).
Secondly, if I set the same motion trigger that works for the light using the fan, I can hear the relay crackling, the light may blink but the fan doesn’t turn on.
I am using the normal ST “device handle” (i hope this is what its called), i removed the SmartThings Multi-channel Control because the two switches it created would just remain in the ON position.
Sometimes, If i have the light turned on with the app, and switch on the fan it turns off the light.
Both the fan and the light work with the manual switches.
Where do I even start trouble shooting this?
Do I try using a the @erocm1231 modules, if so is there a “simple” step 1-2-3 guide?
Is this an electrical / wiring problem?
For what its worth I did a z-wave repair and found no issues.
Had the same issues as the posters above, the problem is that the dual relay switch has a lower max load, I think about 5A on each channel. If you use it with a bunch of CFLs/LEDs and an exhaust fan, it will fail sooner or later because CFLs especially have huge inrush currents. Same with inductive loads like fans, there’s a sudden spike when you first turn on the fan. I believe the mechanical portion of the relay gets jammed when this happens, and you won’t be able to toggle on or off.
They work perfectly and I’ve had no issues.These tiny relays aren’t made for such high loads. If you absolutely must use a relay due to space considerations, you will need two of the single relays. There’s a reason why there’s not much of a price difference between the dual and single - the rated load is halved on the dual relay, which means it’s probably the same thing internally!
Great haven’t try it yet I like to ask you since I am new to this and want learn if it is possible to add code that responds to toggle switch positions,
Something like if the relay is turn on by smartthings the toggle will be off we know this has to be but what if this could be cured at the switch if some go’s to shut off at the switch and smartthings has it on then do nothing until you shut off again to right position. and of course the other way around.
This would help me a lot as it drives my crazy when is in wrong position.
Thank you
Walter
This isn’t possible programatically, but some relays have the option to do as you describe. Fibaro for example. From the Fibaro manual:
Switch type
This parameter defines as what type the device should treat the
switch connected to the S1 and S2 terminals.
Available settings: 0 - momentary switch 1 - toggle switch (contact closed - ON, contact opened - OFF)
2 - toggle switch (device changes status when
switch changes status)
Default setting: 2 Parameter size: 1 [byte]
I have a issue getting my Enerwave ZWN-RSM2 device to add correctly to ST’s. I had this device working great for over a year with no issues. I had a power outage that caused a few of my devices to disappear from my devices list. No problem adding them back; all except the Enerwave ZWN-RSM2. I excluded it and then added it. The problem is it is added a duplex receptacle. I have no idea why it is not showing up as a switch. Any help would be appreciated.
First of all thanks for the great plugin… it works through smarthings app. But somehow I am unable to use the Google Home integration to switch on/off this relay. It shows up on Google home but doesn’t respond… Is it fixable or is that a limitation of all custom device handlers? Thanks!
does any one know how to turn on pairing button without opening up the switch and manually pressing the pair button? any code to turn on and off the button that would put it in pairing mode?
@erocm1231 hey there…i just recently purchased a ZWN-RSM2-PLUS and I am lost. I normally purchase the straight z wave switches, but this time I took at a chance at purchasing two of these relays, to use with my existing switches, to control 2 separate gang boxes, each with two 3-way switches in them. I originally installed your handler code but could not get it to work. Then, i deleted that and just tried to use the ST multi-channel control. At this point, I am so confused and will return these things if I cannot get these things working. I have been looking online a lot and i am going in circles.
On my device is says:
Model: ZWN-RSM2-PLUS
FCC ID: ZZHZWN-RSM1S
I am asking if you could just provide me the steps from a-z with what i need to do. Also, can you include a diagram of the hook up to make sure i have them connected properly.
I currently have one of these installed and here are my issues:
one side of the 3 way does not manually turn off lights, it just flashes the lights
when using ST, it is not turning off lights
Right now in my ST app i have three things showing up: <- none of them working correctly
switch endpoint 1
switch endpoint 2
z-wave device multichannel
hoping you can help as you seem to be the master.
if it helps, i can always give you my cell phone to discuss via phone.
I don’t know what changed but I have one of these dual relays that reports in IDE as firmware version 5.12.
It was pretty easy to connect but I am having an issue with it not reporting back on switch 2.
If I turn on physical switch 1, in 1 to 2 seconds it will show as “on” in the SmartThings app. If I turn it off, it will also report in the Smartthings App.
If I turn on the physical switch 2, it will turn on the light but it will not show as “on” in the SmartThings app.
If I refresh in the SmartThings app it will then show as “on”.
I am using @erocm1231’s Parent and Child device handlers. Other than switch 2 not reporting back on a physical switch change everything else seems to work fine.
I am running into the same issue with this device handler controlling two of the three speeds on my Quietcool WHF.
I finally got the 06-16 device handler and the child devices configured properly but am not getting a status update from R2.
The logs aren’t helpful as there is no status sent when the switch is thrown manually. I do have control and get status messages when triggered via the app. I am also assuming the micro controller is functioning properly because it turns the fan on with both low and medium switches.
@Kraftwerx did you install the SmartApp (not just the Device Type Handler)… if not, go to the OP and see the Virtual Physical Switch Sync app… If you do have all 4 configured (parent device, 2 children switches & smartapp) and correctly configured, it should work.
