[OBSOLETE] D-Link Camera Manager (Connect) [Requires Classic App]
Hello, I have a D-Link 5029Lon a different router than my hub in the house. Is there a way to use the external ip address instead? It is already port forwarded.
Unfortunately not. The DTH uses the HubAction command which requires a local network connection between the hub and the device. Video streaming, however, will work fine no matter where the hub and camera are.
How do I get all the required info from my 5020L’s in order to set them up? I cant get the mydlink.com to work and me settings
Anybody have any luck with figuring out the 936L? I can help test if needed.
You should be able to get all the info from the advanced settings page of your camera. I’m order to get there you will need to be on the same local network and go to the camera IP within a web browser.
Ben in my IDE the apps are Black is there another Github depository that I should be linking to?
Black means they are fully linked and updated.
OK then what is green and red?
Is there any way to turn on/off Sound Detection (DCS-2630L)?
It might be but I’d have to look into it. I’m not sure if it has an API call or not.
I’m running into an issue where I can only see video in the in ST when my phone is not connected to my home router. If I’m on the same network as my router i can’t see the live video. Taking a snapshot works though.
I believe this is actually a router issue though. I have ddns and port forwarding setup and working on router and in camera settings for the app I’m using the external IP for the video. If I use a web browser to try to get to the cameras page, I cannot reach it using the external IP if my phone is connected to the router, but if I disconnect a d use 4G I can reach it.
Router is a Linksys EA8500. Any suggestions on how to fix it?
That is very strange, not sure how to fix that. The streaming video is direct from the camera to the phone, it doesn’t hit the hub at all. Sounds like something is preventing your phone from hitting the external IP while on the local network. Can you get the stream working using your external IP in VLC?
I appreciate the help. However I can’t get to the advanced settings. No matter what browser I try it keeps blocking me. Something about a Certificate. Could I possibly send you some screenshots?
That’s beyond me, sounds like something you need to go to D-Link support about.
Could be you are trying to access via https and you don’t have a valid security certificate. Can you either go to advanced and accept the invalid certificate (Continue anyways) or try using http instead of https?
Is there a way when a camera detects a PIR Motion event that it can trigger a motion event in ST?
Unfortunately not, this is currently a one way integration. SmartThings can send commands to the camera but not the other way around.
:frowning: So I guess the only way would be to set up email notification within the camera and use IFTTT.com, to trigger a virtual motion sensor?
Correct but there will be a significant delay.
Could you share the config for 5222L, I was not able to get it working
