The motion sensor does not integrate into SmartThings, only the control of the motion sensor. It’s a large distinction as you cannot trigger anything directly from a motion event from the camera currently.
what do you get if you type the following into a web browser while on the same local network?:
Well that’s the issue, you’re not getting an HTTP response from the camera. Are sure that the IP, Port, Username and Password are correct? Are you able to take a still image?
Ben, would it be possible to get the image from S3 bucket so that users can access it from anywhere, not just local network. I am using your D-Link camera DeviceManager
@KuldipPabla Unfortunately the Image capture capability has depreciated and there is no documentation on how to do that. There may be someone far smarter than me that can figure something out but I only have the implementation as it is now. Once you take a photo in smartthings, you can click on the photo within the multi-tile on the device to download it to your phone.
When going to that url, it asks for the username and password again, regardless of if it’s in the URL. Once I enter it I get a response showing motion is disabled and PIR is enabled.
Did you change any of the security settings in the camera’s advanced settings? It seems that the issue is that the camera is not accepting the URL with the user/pass in it, without this you won’t be able to do anything other than get a still image.
Just an update, I didn’t change any settings but I did hit refresh tile, at which point the motion tile updated to on and everything started to work… Any idea why refresh had to be hit for everything to start working?
I have added both of my cameras, the DCS-931 and DCS-932. It would appear that they need to have passwords set for the app to be able to pickup the video feed. In the process I created too many things for my 2 cameras, and the error I get when trying to delete the extra things is this:
deleted object would be re-saved by cascade (remove deleted object from
associations):
[physicalgraph.app.InstalledSmartApp#23ef4d95-1bd2-4c7d-a720-430f032b2253];
nested exception is org.hibernate.ObjectDeletedException: deleted
associations):
How does one fix this? Thanks and this app is awesome!
