Status Category OAuth Locations
blebson : D-Link Camera Manager (Connect) Published Safety & Security
blebson : Dlink PTZ Video Camera Child Unpublished Safety & Security
blebson : Dlink Video Camera Child Unpublished Safety & Security
Sorry, just to confirm
Your tapping from the -
Smart Home Monitor
āMarketplaceā bottom right corner
Then āThingsā or āSmartAppsā
āSmartAppsā
Then the bottom tab should be + My Apps
That right?
If while in IDE you switch to the āMy Hubsā tab, it shows your hub and all of your devices?
Yeh so when the app opens, I go to marketplace in bottom right, then smartapps and there is no option for My Apps.
Yep all there.
Very very oddā¦ itās as if SmartThings doesnāt see that you have any custom SmartApps installedā¦
Its weird because i have some and Iām using themā¦I will raise a support ticket and hopefully will get something backā¦ I think i might do a reset as well as they will only tell me to do that!
Gary, can you see any smartapps you have installed?
Have you installed any others?
I can see ones I have done before. But I just tried setting up one from a template and that doesnāt appear eitherā¦I think it could be a bigger issue unfortunately.
I was just given the suggestion to have you log out of your SmartThings app on your phone and log back in. See if that fixes it.
Just tried and didnt make a difference
I would open a support ticket. Add slagle@smartthings.com to the cc: line as well for some visibility
Just have a look at thisā¦
I will try this later tonight, very cool and Iām ecstatic about your progress with video!
Question: any reason why DCS-5010L is not on the supported list? Thatās what I have and will let you know if the 5020L driver works for my 5010L camera ---- which it did with your older driver for 5020L that Iāve been using for a long time with my 5010L. FYI, those were blown out at Groupon for $70 like 2 years ago, so there are lots of 5010Lās out there. Iāll keep you posted on how it works out for me.
Let me know if the DCS-5020L DTH works and Iāll add it to the app! Thanks!
I just updated the D-Link Camera connect and my camera connects for a second then drops out. If it does load it loads once then doesnāt load again. I have the DCS 934L
If it loads even once then it is a network issue on your end, not much I can do.
When I went to repo and checked the update it said updated, but it didnāt save it. I had to exit IDE and then click save and publish now it works. I think there might be a problem with the repo server. I had my neighbor complain about the same problem. Could also be a quirk in the new IOS update that came exactly at the same time I was doing the repo update. All is good now.
