Got an example use case? Just trying to understand.
Here you go. Maybe thereās a different/better way of doing it? Just what I was used to in CoRE thatās all. The example below is āin the last x seconds/minutes/hoursā but I also use āfor at least x seconds/minutes/hoursā. Itās to check that someone has been away for a certain amount of time and some else has been home for a certain amount of time. I also use if motion hasnāt happened for x amount of time.
Where are we supposed to ask about CoRE features (given the fact that it is possibly changing to a web controllable app)?
Iām specifically trying to figure out how to get CoRE, which I installed via GitHub integration without too much trouble, to control full RGB colors on my OSRAM Lightify Flex. Unfortunately the Flex isnāt showing up as a full color device and Iām not sure why. Iām a noob with ST and Lightify both, so maybe Iām missing something obvious.
Hi - I noticed twilio sms two-way setup in the source that is commented out.
I am wondering what this will be, as having a piston respond to an SMS message and performing a task and responding back would be very interesting.
Hey guys, I need a little help with Variables. Iām using the AutoMatic device type to track my cars fuel level. It uses fuelLevelPercent. How would I have CoRE track this?
