I tried the Remove option but it keeps coming up with " An unexpected error occured"
Try through the IDE instead of the mobile app.
- Login at https://graph.api.smartthings.com/
- Go to My Locations
- Click List SmartApps
- Click Edit (top right of the page)
- Scroll down to the SmartApp that you wish to remove
- Click Uninstall
- Click Done (top right of the page)
- Exit the mobile app and re-launch (Android may require logging out and back into the mobile app).
- You should now see that the SmartApp is removed. You can now reinstall if you like.
Appreciate it⦠keep getting message There was an error uninstalling the Smartapp.I dont know whats happeningā¦
It sounds like you may have to send an email to support@smartthings.com to have them check into why you are unable to remove/uninstall the SmartApp and have them do it for you. Sorry, I do not have any other suggestions.
Thatās awesome JD! Iām a PTA and learning this home automation stuff can help me and my patients. Thanks for the help that you have offered me!
I am having some issues with this automation recently.The lights are going off at irregular time.I set it to go off for 3 mins after someone leaves or there is no motion,but its going off at 6,10,17 mins.Not sure whats happen,
I have tried to reinstall it but its not working.
Can you help you out.
Having some issues with this automation after a year or so. it seems that the check or reporting interval is every 30ish minutes in the app so it not always recognizing the humidity change while Iām in the shower. anyway to have it check/report every 5 minutes?
It is event driven based on when your motion & humidity sensors report changes to SmartThings. Various sensors use different wakeup/reporting intervals. You will need to check in your motion/humidity sensorās ST driver to see if the reporting interval is configurable and if it can be decreased to what you want.
