[OBSOLETE 1.1.6 5/25/16] Big Talker - Talk when events occur
first of all i want to thank Brian for making Big Talker, i really love the idea and i hope it’s gonna work for me;
big talker is not talking to me :frowning:
it seems that it sets the volume(i can see that the volume is changed by big talker), but doesnt talk.
i used live logging but it is abra cadabra to me, and then i mean abut the error, its missing a method?
hopefully anyone can help me
error groovy.lang.MissingMethodException: No signature of method: physicalgraph.device.HubSoapAction.leftShift() is applicable for argument types: (physicalgraph.device.HubSoapAction) values: [POST /upnp/control/transport1 HTTP/1.1
Accept: /
User-Agent: Linux UPnP/1.0 SmartThings
Host: 192.168.0.103:49152
CONNECTION: close
SOAPAction: "urn:schemas-upnp-org:service:AVTransport:1#Play"
Content-Type: text/xml; charset="utf-8"
Content-Length: 305
Hm. I am using smartthings 1.6.9 which makes it possible to use the lario HD player again (newest version of smartthings gave trouble playing sound over the lario). I can use the alarm to play the dogs bark on the same speakers using the lario HD player. So it should be possible, imo.
My Sonos Resume after play was not working with the standard Sonos Labs smartapps and so I installed and tried Big Talker 1.1.0 because of the positive comments in the community. Sad to say that my Sonos does not resume with the Big Talker either. Has anyone else run into this issue with the Big Talker? It seemed most others are getting it to work.
Danny
Can you try the beta version that I have (currently 1.1.1Beta2) where I am attempting to resolve the resume issue?
https://github.com/rayzurbock/SmartThings-BigTalker/tree/Fix-ResumePlay
What devicetype does your lario HD show up as in SmartThings? How are you adding it to SmartThings?
Thanks for your support!
My Lario HD devices type is “DLNA player”
I am adding it to smartthings by using the MediaRender (connect), in that app it will search for the lario and add it.
It would be great to have feature to announce repeatedly ( with custom time interval) when door is left open for some variable time.
well in my haste i did not read above hopefully with the platform upgrade tomorrow this will work then???
it seems the sonos just doesn’t recognize it is getting a command I setup a time and day to say a phrase just to test it and I can watch in the activity feed of the sonos speaker that big talker dev sent playtextandresume command to kitchen sonos …but the speaker just continues on as if nothing happened…Did I set it up wrong? I setup my kitchen speaker as my default device left check speech device at every 1 min set volume to 50 and talk when in home mode only
Is it possible to set notifications not based on home mode but for only when one particular person is presence? Reason begin is that I would like my wife to get sonos notifications when certain exterior doors or window contacts opened when she is the only person home but not when another particular person(s) are presence. Thanks!
This error, physicalgraph.device.HubSoapAction.leftShift() is applicable for argument types: (physicalgraph.device.HubSoapAction) values..., looks to me like an issue in the MediaRender deviceType or SmartApp. Basically BigTalker is making the call to play audio and then the rest is handled within the deviceType code, which in your case is the MediaRender deviceType/SmartApp. I do not make calls to physicalgraph.device.HubSoapAction or to physicalgraph at all for that matter. Does the developer of the MediaRender devicetype have a newer version of their DeviceType and/or SmartApp that you can try with? If not, you might want to let them know that you are trying BigTalker with MediaRender and give them this error that you are getting back when the MediaRender devicetype/smartapp attempts to play the audio.
I actually have a SmartApp that someone else wrote and I customized prior to writing BigTalker to do this in my home (Door Left Open). It repeats up to 10 times (configurable); however I haven’t written my own code to do this into BigTalker yet. I intend to add this and door knock announcements when I get some time to devote to it. I’ve been busy with work and family for quite a while and haven’t had the time needed to put into it.
This is likely the problem: SmartThings Text-To-Speech for Sonos (playText) not working?
It looks like SmartThings backend method for converting text to speech in an mp3 audio file and sending that to your hub/device was broken somewhere around Aug 5, 2015.
Does this app work with Amazon Echo?
No, because there is no TTS (Text To Speech) capability in Echo right now.
A lot of people here (myself included) desperately want this to be added to Echo, but right now there is no method* to get Echo to say a custom phrase at all, let alone have it tie in so tight with ST that it can be a device in ST.
(*Okay, there is a method, but it involves you essentially creating an entire back end running on your own server and setting it up as a “skill” within the Alexa app. So, possible, but extremely involved.)
Edit to add: There’s also another pseudo-method to get notifications on the Echo. You can, with the right software, setup an android tablet as a Text-To-Speech device within SmartThings. Then pair it with Echo as a BT speaker. Again like the above example, it involves some work, but a lot less than developing your own Alexa Skill. And you’re not really using the Echo as anything more than just a speaker in this case.
Sucks! I am leaning to Alexa instead of Sonos. As Alexa can take voice commands and give audio responses. Sonos…just sound.
Yup, and the Echo really sounds very good as a music speaker too. Works great with IHeartRadio.
I’m using Ubi right now for some voice announcements and I actually paired it to the Echo for the speaker because Echo’s speaker is so much better. But I’m considering getting an older Android Tablet and setting that up with the TTS software (like I indicted above) as I could then also use that tablet for a interface and maybe some other stuff too.
Still working that through.
If I was a betting man, I suspect TTS will come to the Echo at some point. But I just don’t know when.
Release Announcement:
  1. Version 1.1.2 Released 10/25/2015 with 2 bug fixes
  • 10/25/2015 - 1.1.1 - BugFix: Corrected issue with Motion 1 announcement custom time restrictions - Broke BigTalker if used
  • 10/25/2015 - 1.1.2 - BugFix: Corrected issue with setting speech volume. Ensure that Volume is not 0; Set to 75 if it is. May have caused phrases to be spoken inaudible.
  • Available here: https://github.com/rayzurbock/SmartThings-BigTalker/tree/master
  1. Version 1.1.1.Beta4 Released 10/25/2015 (Beta Testing Version)
  • 5/31/2015 - 1.1.1.Beta2 - BugFix: Attempting to update speech device current status with .refresh() (currentSpeechDevices*.refresh())
  • 10/25/2015 - 1.1.1.Beta3 - BugFix: Corrected issue with Motion 1 announcement custom time restrictions
  • 10/25/2015 - 1.1.1.Beta4 - BugFix: Corrected issue with setting speech volume. Ensure that Volume is not 0; Set to 75 if it is. May have caused phrases to be spoken inaudible.
  • Beta Available here: https://github.com/rayzurbock/SmartThings-BigTalker/tree/Fix-ResumePlay
(I got sick and had some time to work on this project finally):
  1. Version 1.1.3 Released 10/26/2015
  • BugFix: Added additional check in Talk() if using MusicPlayer device, currentTrack = null and currentStatus was “playing” then BT would not “resume”, but instead would stop the track, PlayText() and not resume the track.
  • BugFix: Replaced deprecated “refreshAfterSelection” in dynamic pages with replacement “submitOnChange”. This fixes things like TalkNow’s expected operation.
  • Feature Enhancement: Additional logging added in Talk()
  1. Version 1.1.3-Beta5 Released 10/26/2015 (Beta Testing Version)
  • Version Adjustment: Modified from 1.1.1.Beta4 to 1.1.3.Beta5 (Current Master branch = 1.1.3)
  • BugFix: Added additional check in Talk(): if using MusicPlayer device, currentTrack = null and currentStatus was “playing” then BT would not “resume”, but instead would stop the track, PlayText() and not resume the track.
  • Beta available here: https://github.com/rayzurbock/SmartThings-BigTalker/tree/Fix-ResumePlay
Thanks Rayzur…
Could you update this to support the new smartthing github format? (So we can add\update from the IDE directly)
Thanks…
