Hi, @LycheeThings. Welcome to the SmartThings Community!
Can you provide more details about what you’re trying to do, please?
Based on the URL you mentioned, I’m guessing you’re working on an ST Schema integration.
So, when you go to add your device, it should redirect you to your OAuth server configured in the developer workspace, for example, https://yourdomain.com/login. After the user authenticates, you need to redirect the response to the callback with the generated auth code by your server.
Hi @nayelyz, Yes we can see it goes to our server URL with the callback configured to SmartThings US (https://c2c-us.smartthings.com/oauth/callback). At the time of adding the device, instead of showing the login UI of our Auth page for the user and password it directly jumps to the callback link and throws an error with a different error code every time.
Just one confirmation as Lambda has the restriction for the Virginia server, is there any limitation on user pools to be in the same region server for AWS?
We have the same process working with Google Assistant and Alexa with a similar configuration but with SmartThings we are not able to get past the Auth process. Are there any logs on SmartThings to check what is the error?
For a user to install the Connector, the SmartThings Location’s region needs to match the one from AWS, for example, you cannot install a Connector that belongs to a region in Asia if your location is in Europe. And, also, if you have it in another location different than us-east-1, it could be an issue.
Can you share the following info to ask the engineering team to check the logs related to the error you see, please?
Last error code
App ID, is located in the Developer Workspace, for example, viper_xxx...
Hi, @LycheeThings
Following up, the team checked the error based on the code you provided and the message shown specifies that the OAuth URL is trying to use invalid scopes. They must match the ones you specified in the Developer Workspace.
Could you share over a DM or by email to build@smartthings.com the current configuration you have for the connector in the Developer Workspace, please?
This is to check if something else could cause an issue.
