NYCE Tilt Sensor Issue
I have been using an NYCE Tilt sensor since Jan 7, 2017. Has anyone developed (not found in my GitHub searches) a driver for it? The reason being is with the transition of drivers by Samsung, it tilt sensor isn’t working anymore. If I bring it in the house, and take the batter out / put back in, it registers, put in a new battery, same results. When back to its original position, tilt position doesn’t change, yet the battery % does update between the three different batteries I’ve tried (e.g. last test Sep 14, 2023, 11:21 a.m).
What tilt sensors do others use, should I need to replace (z-wave preferred).
