I used to be able to use the ST app in this Android emulator. For the past month or so it just crashes and will not let me sign in. I can open it but that is about it.
Are you using any other emulator successfully? A Windows or QT app would be really helpful Samsung.
Thanks for the info about the Windows app. Sooooo, it looks ok but I cannot see the properties for any devices. I want to see the history for a device but that is not possible Unfortunately this issue is common in the reviews but it appears that Samsung doesn’t care.
I can install it using v9 android and this emulator but when I run the ST App it won’t work because it requires location turned on (Ok but why) and then it crashes Nox when trying to use Bluetooth.
I cannot get it to start without location and then I cannot get it to not try to use Bluetooth.
Very disappointed. Why does it care if it knows my location and why require Bluetooth? I do not have any devices that would need that.
