I use this app to monitor my fridges and doors because of my lazy kids. You can set the timer and get a notification. I can’t turn the device off but you can also use ST smart lighting for timers.
Door left open (with Photo Burst, Hello Home, & Speech), Version 1.3.5
(Updated to Version 1.3.5 10/26/2015 - More info here )
Receive Push, SMS alerts, Verbal announcement via speechSynthesis or musicPlayer device(s), and/or run a Hello Home (routine) when a door is left open for longer than x minutes.
Optionally take a few photos of the event.
Optionally receive repeat alerts at each x minutes until the door is closed.
Original code by olson.lukas@gmail.com . Not sure actually where I found this code initially as I have been using the original version for a while, but nonetheless, I added the ability to capture images and also repeat notifications if the door does not close by the time the next alert interval expires. I also received false alarms initially and added some protection …
