Steef
June 30, 2019, 8:58am
1
Noob here. Go easy on me.
I’m trying to test API calls in Postman. It works fine when I GET the following paths:
/devices
/devices/{id}
/devices/{id}/state
However, when I try to do /devices/{id}/components, I get the following:
"requestId": "B9E52180-2F01-4E51-87D7-C4126F076D7D",
"error": {
"code": "NotAcceptableError",
"message": "Not acceptable according to the Accept headers.",
"details": []
For the call’s Accept header, I’ve tried:
application/json
text/html
text/plain
The response is Content-Type →application/json
Any ideas what I can do?
jbal2or
(Jason)
August 5, 2019, 3:12pm
2
I’m sure you’ve figured this out by now, but I came here because I was getting the same thing, and it turns out I was just missing part of the request (v1/devices/{deviceId}/components requires more path elements as below).
https://api.smartthings.com/v1/devices/{deviceId}/components/main/capabilities/switch/status
A 406 error is inaccurate and unhelpful – it should be sending a 400.
Expanding upon Jason’s example more specifically it should look like this:
https://api.smartthings.com/v1/devices/{deviceId}/components/{componentId}/capabilities/{capabilityId}/status
componentId
is usually main
