I have one of these devices from several years ago that always ran well in IDE with this custom device handler. The advantage to this sensor, in my opinion, is that it has two inputs and a tamper switch. One magnetic contact and one set of terminals to accept an external set of contacts. It also takes a CR123A battery that lasts a very long time. In my application, I need a battery powered device as I am monitoring a custom control box I built for my well water that senses water leaks and shuts off a 220v contactor as well as telling me the current state of mains power using a relay.
In preparation of the changeover to Edge only (this is my last device to convert) I went ahead and deleted the device handler from IDE and added the device again from scratch.
The device is natively supported by edge and shows up using the driver “zwave sensor”.
The trouble is, it really doesn’t work. Connecting either set of contacts just sort of flickers from open to closed randomly or not at all and may settle in either state. That, and it is only showing one set of contacts.
I installed @philh30’s Masquerade driver and that does read open/closed properly for one set of contacts when set in contact sensor mode. Opening and closing either set of contacts changes the state of the contact display in the app.
I decided to give the tutorials a try and see if I could make my own driver but I definitely don’t know what I’m doing.
I followed the tutorials and this thread and have been successful in publishing a broken driver where I have added all capabilities to see what sort of output I get. It is a modified version of the “zwave sensor” driver that loads in default for this device.
It is published on my channel
The fingerprint for the device is:
- id: 014F/2001/0102
deviceLabel: Nortek Open/Closed Sensor
manufacturerId: 0x014F
productType: 0x2001
productId: 0x0102
deviceProfileName: contact-battery-tamperalert
I feel like the basis of the Masquerade driver would be a better start since it does function but the syntax of it is more than I can figure out for now.
What I find interesting from the logcat is that it shows a payload that matches the info on the original instruction sheet in pdf and corresponds to what I am pressing.
Here is that snip:
Any thoughts or help is appreciated. If someone thinks I’m heading the wrong direction and thinks they have something that will work, I’m happy to try it out.
Honestly, spending too much time on it may not be worth it. This is an obsolete sensor that probably is not widely used. I’m open to suggestions on other devices as well. I would use a Fibaro smart implant if a battery power option were simpler. My control box runs on 24v AC but I need the sensors to stay powered during an outage.
Thank you!
2023-03-02T21:15:38.907856594+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:38.908764594+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={value=255}, cmd_class="BASIC", cmd_id="SET", dst_channels={}, encap="NONE", payload="\xFF", src_channel=0, version=1}
2023-03-02T21:15:38.924621136+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:38.925073594+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> emitting event: {"attribute_id":"contact","capability_id":"contactSensor","component_id":"main","state":{"value":"open"}}
2023-03-02T21:15:38.938507219+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
2023-03-02T21:15:38.966287803+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:38.971280136+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={alarm_level=255, alarm_type=7, event="INTRUSION", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=255, v1_alarm_type=7, z_wave_alarm_event="INTRUSION", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\xFF\x00\xFF\x07\x02\x00\x00", src_channel=0, version=3}
2023-03-02T21:15:38.986375136+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:38.986824969+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:38.987748636+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> emitting event: {"attribute_id":"contact","capability_id":"contactSensor","component_id":"main","state":{"value":"open"}}
2023-03-02T21:15:38.997840094+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.000086261+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2023-03-02T21:15:39.008160469+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.009997969+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.016279344+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.016748594+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.017391969+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.017998678+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
2023-03-02T21:15:39.331431261+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:39.335794136+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={value=0}, cmd_class="BASIC", cmd_id="SET", dst_channels={}, encap="NONE", payload="\x00", src_channel=0, version=1}
2023-03-02T21:15:39.346205178+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.346654469+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> emitting event: {"attribute_id":"contact","capability_id":"contactSensor","component_id":"main","state":{"value":"closed"}}
2023-03-02T21:15:39.381256011+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
2023-03-02T21:15:39.384697636+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:39.385230553+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={alarm_level=0, alarm_type=7, event="INTRUSION", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=0, v1_alarm_type=7, z_wave_alarm_event="INTRUSION", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\x00\x00\xFF\x07\x02\x00\x00", src_channel=0, version=3}
2023-03-02T21:15:39.402679136+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.403267136+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.404109969+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> emitting event: {"attribute_id":"contact","capability_id":"contactSensor","component_id":"main","state":{"value":"open"}}
2023-03-02T21:15:39.407989428+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.415835928+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2023-03-02T21:15:39.418754594+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.419348511+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.420185386+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.420803969+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.421419178+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:39.424172928+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
2023-03-02T21:15:48.111969432+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:48.125314640+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={alarm_level=0, alarm_type=7, event="UNKNOWN_EVENT_STATE", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=0, v1_alarm_type=7, z_wave_alarm_event="UNKNOWN_EVENT_STATE", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\x00\x00\xFF\x07\xFE\x00\x00", src_channel=0, version=3}
2023-03-02T21:15:48.126183557+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:48.126831182+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:48.127453890+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:48.128205390+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:48.129061265+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:48.129689849+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:48.130312474+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:48.130938640+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:48.131551890+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
2023-03-02T21:15:50.578069516+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:50.580572433+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={alarm_level=255, alarm_type=7, event="UNKNOWN_EVENT_STATE", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=255, v1_alarm_type=7, z_wave_alarm_event="UNKNOWN_EVENT_STATE", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\xFF\x00\xFF\x07\xFE\x00\x00", src_channel=0, version=3}
2023-03-02T21:15:50.589397350+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:50.591040558+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:50.666466808+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:50.676596725+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:50.677067642+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:50.677717058+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:50.678341850+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:50.678953267+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:50.679557017+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
2023-03-02T21:15:51.529827642+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:51.532183475+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={alarm_level=0, alarm_type=7, event="UNKNOWN_EVENT_STATE", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=0, v1_alarm_type=7, z_wave_alarm_event="UNKNOWN_EVENT_STATE", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\x00\x00\xFF\x07\xFE\x00\x00", src_channel=0, version=3}
2023-03-02T21:15:51.566288725+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:51.568119059+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:51.569757850+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:51.574268142+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:51.574738725+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:51.575453059+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:51.576078725+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:51.576698934+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:51.577315309+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
2023-03-02T21:15:53.988097560+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:53.990601101+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={alarm_level=255, alarm_type=7, event="UNKNOWN_EVENT_STATE", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=255, v1_alarm_type=7, z_wave_alarm_event="UNKNOWN_EVENT_STATE", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\xFF\x00\xFF\x07\xFE\x00\x00", src_channel=0, version=3}
2023-03-02T21:15:53.999463976+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.001093393+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.002721143+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.007312476+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.007775893+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.008422476+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.009037560+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.009651768+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.010262643+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
2023-03-02T21:15:54.618037185+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:54.620397393+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={alarm_level=0, alarm_type=7, event="UNKNOWN_EVENT_STATE", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=0, v1_alarm_type=7, z_wave_alarm_event="UNKNOWN_EVENT_STATE", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\x00\x00\xFF\x07\xFE\x00\x00", src_channel=0, version=3}
2023-03-02T21:15:54.629082518+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.630729560+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.666384143+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.670531602+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.670996560+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.671639393+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.672253643+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.672866810+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:54.673471935+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
2023-03-02T21:15:57.998467312+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:58.000842770+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={alarm_level=255, alarm_type=7, event="UNKNOWN_EVENT_STATE", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=255, v1_alarm_type=7, z_wave_alarm_event="UNKNOWN_EVENT_STATE", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\xFF\x00\xFF\x07\xFE\x00\x00", src_channel=0, version=3}
2023-03-02T21:15:58.009677687+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.011318270+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.012949853+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.026570520+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.027042478+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.027679812+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.028294687+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.028906228+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.029517978+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
2023-03-02T21:15:58.672056270+00:00 TRACE Nortek WADWAZ-1 Received event with handler unnamed
2023-03-02T21:15:58.674545854+00:00 INFO Nortek WADWAZ-1 <ZwaveDevice: a42fd89e-3cda-43ed-89f2-f1027d93789e [02] (Nortek WADWAZ-1 DW Sensor)> received Z-Wave command: {args={alarm_level=0, alarm_type=7, event="UNKNOWN_EVENT_STATE", event_parameter="", notification_status="ON", notification_type="HOME_SECURITY", v1_alarm_level=0, v1_alarm_type=7, z_wave_alarm_event="UNKNOWN_EVENT_STATE", z_wave_alarm_status="ON", z_wave_alarm_type="BURGLAR", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x07\x00\x00\xFF\x07\xFE\x00\x00", src_channel=0, version=3}
2023-03-02T21:15:58.683803937+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.685502354+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.687190812+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.691894645+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.692368229+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.693013645+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.693637812+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.694253270+00:00 TRACE Nortek WADWAZ-1 Found ZwaveDispatcher handler in zwave_sensor
2023-03-02T21:15:58.694868270+00:00 DEBUG Nortek WADWAZ-1 Nortek WADWAZ-1 DW Sensor device thread event handled
