So this will Proably be simple for many of u but my brain doesn’t work that great with this stuff yet. All I want is any dimmer switch that is on do lower to 15 percent if no motion. I was able to do it except switches that were already off turned on and set to 15 percent. The ones that are off I want to stay off. Any that are on i want to dim to 15
That’s what I have now. It’s a basic not sure why it says and of
I don’t think that will work. If it changes to inactive, then it will have changed in the last 15 minutes. Unless it evaluate the 15 minutes prior to status change. But just have to try it and see.
If that doesn’t work just change to if motion is inactive and hasn’t changed in 15 minutes.
So basically reverse my first couple of rules. I see if if this works. That is if my wife would stop walking around. Should I be concerned that when I’m setting things up core shows lights on that currently aren’t on?
