No matter what I do I can't get Echo, Harmony hub and ST to cooperate
I followed all the instructions to a tee
  1. Installed harmony smart app on ST
    Went through all the steps to sync and no hiccups
    All the activities/switches are present & accounted for
  2. Installed ST skills on Alexa
  3. Alexa recognized all my activities/switches
  4. Give the command to Alexa “satellite” to watch directv which should turn on and select appropriate inputs for all the appliances for that command. I just hear that dull noise from Alexa when a command is not working.
Echo Works perfect with ifttt and also if I use my remote not with “Amazon Echo and ST”
Any advice would be appreciated as I am about to return it after hours of fustration.
9 posts were merged into an existing topic: Smartthings+Echo+Harmony Hub = Voice Controlled TV! (2016 version)
I’m sure that’s very frustrating! If you ask your question in the following thread, the people there should be able to help you, they all have the integration working. :sunglasses:
