*** No longer supported *** [RELEASE] Best Zoned Heating/Cooling smartapps
Hi,
Just to let my contributors know and all ST users who would like to do targeted heating/cooling in their home that I have new versions of my zoned Heating/Cooling smartapps available at my store :
  • I made some correction to ecobeeSetZoneWithSchedule (v8.7.7), and ScheduleTstatZones (v8.7.6c):
    • When using the moreHeat, lessHeat, moreCool, and lessCool thresholds based on an outdoor temp sensor or weather station, the check_if_hold_justified() routine will take into account the null values to revert the adjusted setpoints if needed.
    • Added more tracing in the code
For more details about the all use cases supported, refer to ST community wiki:
EcobeeSetZoneWithSchedule (for the main ecobee thermostat only)
http://thingsthataresmart.wiki/index.php?title=EcobeeSetZoneWithSchedule#Look_.26_Feel
ScheduleTstatZones (for any ST connected main thermostat like the Nest, Honeywell, etc.)
https://thingsthataresmart.wiki/index.php?title=ScheduleTstatZones#Look_.26_Feel
ScheduleRoomTempControl (for any ST connected main thermostat with smart vents).
https://thingsthataresmart.wiki/index.php?title=ScheduleRoomTempControl#Look_.26_Feel
P.S. For all ST users who have contributed to my support packages, the update has been done for you under your ST account (provided that I have your credentials), you don’t need to do anything: everything has been taken care of.
You can download the new version at my store using the original sellfy link.
The new code is available at my store.
www.ecomatiqhomes.com/store .
Regards.
