Seems to be a smartthings issue. From an email I just got: “Users are receiving an error when attempting to edit or update a SmartApp or device handler which is associated with Github. We are actively investigating.”
As many of you know, @tonesto7 (Tony) asked me to beta test his Community Installer and help write the documentation. Something else many of you know is that Tony also took the mantel for Echosistant as the original authors moved to ST competitor, Hubitat. As Tony and I worked together and discussed both of our products, we came to the conclusion that we had more similarities than differences in our respective Alexa SmartApps. While each developer has his/her own style and philosophies about coding and product design, in this case we got past those and decided that for the benefit of the community we would NOT compete with each other, but instead find a way to merge our apps’ respective ‘technologies’ into one product.
Echosistant v5 will now be shelved and instead Ask Alexa will inherit some of the install features of this unreleased version Tony and team have been working on. This will take away the last major hurdle for a beginner to start using Ask Alexa immediately. Tony’s install code will allow you to tap a few buttons and AUTO DEPLOY/UPGRADE your Amazon Lamba and Developer account. This means auto creation of the skill(s), or updating of the skills when you make a change to the parameters of your application. No more need to copy and paste between screens; however, for those that WANT TO manually install it yourself you will ALWAYS have that option.
This collaboration is really in the spirit of what SmartThings intended by allowing the core functions of SmartThings to be enhanced by the community.
As for a timeline, we are working on a schedule for integration. The next version of Ask Alexa (v 2.3.9 without the skill and Lambda installer) is already operational and has the Echo speaker identification code it. After that release, we will focus on getting the installer code ready for release (version 2.4.0) . I anticipate the end of March being a target for us. However, we are more concerned with getting it right instead of pushing it out fast.
I am going to post this in the Echosistant threads as well…
Yes exciting news to say the least. I am glad that what some people call Drama is over. I can’t see the fruit of the collaboration. Good luck, and smooth sailing!
As someone who was in an alpha of a random feature of EchoSistant, and had sort of abandoned Ask Alexa as the use cases of echosistant were working for me, what would be the best way forward for me… I’ve been mostly out of town over the last 3 months, and will probably not be home much for the next 2 either.
I’m guessing scrap/delete both apps, and start over with the community installer.
P.S. Excited to see the great parts of both of these apps merging together to create a unified Alexa Interface.
P.P.S. This is also assuming ST fixes the current github integration bug that is preventing me from updating my NST Manager (was on initial tokens), ask alexa, and all my other apps…
Thanks for your note. I should probably clarify what all this ‘merger stuff’ means:
First, users of Ask Alexa won’t have to uninstall and reinstall the app. New features will be immediately available to their installation when they install the latest version. Users of Ask Alexa will see the same program they have always seen and used. NO change in your workflows.
For Echosistant users, Ask Alexa uses different terms and philosophies to designate things. For example, while Echosistant uses “Profiles”, Ask Alexa uses Macros, and Groups. As such, there is no automated ‘migration’ path to Ask Alexa. Instead, I recommend you work conceptually and I can work with you to turn those concepts into actual configurations. So, something like “I want to control this area of my house with this speaker”. In “Ask Alexa”-speak, you will want to create a room/group. There are thousands of installs so the collective mind will be able to help if you can’t figure out something. I am always impressed with the creativity here.
I have never installed Echosistant, so I don’t know if there are features that they had that Ask Alexa couldn’t do (outside of the intercom piece). If there ARE features you want, simply request them. Most questions I get have to do with "I want to say this a specific way’, so most of the time that can be done (through self-service) with a new utterance or two. If you find that, share it! This can benefit the community as well…if you ask a question, odds are 10 other people have the same question.
No one is going to be left out in the cold for being able to use Ask Alexa. I DO recommend reading the documentation before doing anything as many questions will be answered in there. The GOOD news is that this documentation will be radically shortened when we get the automatic installation up and running (end of March). http://thingsthataresmart.wiki/index.php?title=Ask_Alexa
I am getting the message that either I don’t have WebCore installed or I don’t haven’t created any pistons yet, although I have several pistons running in WebCore. Please advise. Thanks in advance.
version 2.3.8
lambda 1.3.0
voice rpt 1.0.0
Is this a new installation or an upgrade of either of the applications? Behind the scenes, WebCoRE is presenting Ask Alexa with a list of the piston names. However, Ask Alexa must be able to ‘listen’ for these names. So, if it is not seeing it, do the following:
Ensure you have ALL of the extensions loaded into your IDE.
Open Ask Alexa
Do not simply leave the application, but click ‘Save’ in the upper right corner to exit.
Open WebCoRE.
When closing WebCoRE, click Save as when exiting
Go back into Ask Alexa. The list of pistons should be appearing
Let me know if that works. If not, we can work together to ensure the ‘listeners’ are in place (which should be automatic).
Here we are at another Friday! I appreciate all of the comments that have been sent publicly and privately about Ask Alexa integrating some of the features of Echosistant v5. The big one is, of course, the ability to ‘auto deploy’ the Lambda and Developer Skill without the copying/pasting of information between screens. I had already started some of this months ago, and with the assistance of @tonesto7, we can finish off that feature.
For those of you that are coming back to Ask Alexa from Echosistant, or were exclusively Echosistant users, WELCOME. I did publish a list of ‘what this means’ and thought I would re-publish that and add to them based on feedback/questions I have received:
First, users of Ask Alexa won’t have to uninstall and reinstall the app. New features will be immediately available to their installation when they install the latest version. NO change in your workflows, or rebranding of the app. Users of Ask Alexa will see the same program they have always seen and used, just with new features.
For Echosistant users, Ask Alexa uses different terms and philosophies to designate things. For example, while Echosistant uses “Profiles”, Ask Alexa uses “Macros”, “Extensions”, “Groups”, etc. As such, there is no automated ‘migration’ path to Ask Alexa; instead, I recommend you work conceptually and I can work with you to turn those concepts into actual configurations. So, something like “I want to control this area of my house with this speaker”. In “Ask Alexa”-speak, you will want to create a room/group. There are thousands of installs of Ask Alexa over the past 2 years, so the collective community mind will always be able to help if you can’t figure out something. I am always impressed with the creativity here!
I have never installed Echosistant, so I don’t know if there are features that they had that Ask Alexa couldn’t do (outside of the intercom piece). If there ARE features you want, simply request them. Most questions I get have to do with "I want to say this a specific way’, so most of the time that can be done (through self-service) with a new utterance or two. If you find that a new utterance works for your, share it! This can benefit the community as well…if you ask a question, odds are 10 other people have the same question.
Based on some feedback I recently heard from some alpha testers ESv5, Ask Alexa will use the same ‘access method’ to Lambda. No additional Amazon services will be used. There were some alpha users that were charged by Amazon after installing the alpha Echosistant. This was NOT a considerable charge per Tony (less than 25 cents). Either way, you should not get a charge by using Ask Alexa; outside of the auto-deployment feature, everything will operate as before and unless you get to a million hits on your Lambda, you should not receive a charge.
Contrary to some additional rumors I heard, I have not and will not be turning Ask Alexa to a ‘pay to play’ model. While you are encouraged to donate to developers that make a difference in your home automation, Ask Alexa is FREE and will continue to be FREE. Last summer I did hire a consultant to come in and we conceptualized a for-fee feature, but I abandoned this idea when I learned Amazon would integrate this feature (and they have).
One feature that both applications had planned and WILL be in the next release of Ask Alexa (March 16!) is the ability to do speaker (Echo) identification. For example, if you are in the bedroom (and have a group created with the devices in that room) and you say ‘Alexa, tell smart things to turn on the lights in here’ it will turn on the lights just in that room. Move to another room and say the same thing, and only THAT room will react. But, why explain this…better to show you….
While the features are working I am putting the finishing touches on the new features. In addition, I am going out of town next week so I will spend the next couple weeks getting the documentation put up and ensuring the speaker identification is working as I expect. So, check back here on March 16th for the these features, and hopefully by April we will get the auto deploy features in and operational.
Oh, and let’s end with the logo change for SmartThings…Already implemented this in Ask Alexa…you may have to clear your app’s image cache, but the backend image has changed:
Hello, First time setup here, I managed to get everything working, I can run the service simulator and get a response, however when I check my logs on the hub I see the following:
postEventToEndpoint: Error while trying to post event back to Amazon groovyx.net.http.HttpResponseException: Unauthorized
Any idea what is causing this and how to fix it? It’s on every command being done by askAlexa. OAuth is enabled.
Second, I have several Echo Dots and an Echo, how can I get them added into askAlexa to be able to select an echo device within askAlexa? Thank you.
When you say you managed to get everything working, do you mean that you are able to do voice commands? Why are you only running the simulator? If the voice commands don’t work on the device then it is not working and we need to start with that.
Let me know what exactly you mean in terms of ‘working’. I would start by doing this:
Alexa, open smart things…does that work?
If so, give a command to a light…does that work?
Yes, I can give it commands and it turns on and off lights no problem. I want to use Alexa natively with my devices to turn stuff on and off, I was hoping to use askAlexa for reporting and status updates primarily on devices. I don’t have any verbal errors just the one I showed which shows up in the smartthings log. I was hoping to use this to get a battery report of my battery operated devices along with the tips from my ecobee thermostat and various other reports, however I’m finding it difficult to get Alexa to tell me what I want to hear.
I created 2 message queues, one called battery, and another called Weather. When I ask Alexa to tell me my daily weather report (which is what I called the report), I get a report which is pretty lengthy. I created a second report to the same queue called “tomorrows weather report” but it won’t read it back. It fails with no error, just acts like there’s no data. I setup a Battery report to a battery message queue for which I thought when I asked it for a battery report but it just tells me I have a report called “Battery”.
I re-ran my ecobeeinit and turned on the tips for my Ecobee 4 for askAlexa but I’m not sure how to get them to play (right phrase)?
Thanks for any tips / tricks / help you could provide. I also have my install working with WebCore as I managed to create virtual switches which I am using with WebCore to use Alexa to turn on and off light switches that are motion activated to keep them on and ignore the motion.
Regarding your first question (let’s take these one at a time):
So you are running a weather report from Ask Alexa? How are you invoking that? Is it something like “Alexa, Ask Smart Things to play {report name}” ? If you are getting no output from the speakers, is the live logging (in ST’s IDE) showing any error? Make sure you filter for Ask Alexa. Did you update the Amazon Developer’s slots with the name of your report?
Without knowing what is in your report or what you are saying (or what the log is saying) I am kind of shooting in the dark here. Can you provide a bit more information?
Just trying what you mention, here is what I found. First, you probably need to rename your report from “weather” to something else. “Weather”, by itself is a reserved word so you will come up with some confusion in Ask Alexa by using that word. I created a report called “Tomorrows Weather” and that worked.(but I strongly recommend removing weather from any title):
I also changed the name to Tomorrows Weather Report. Again, ran into a bit of difficulty because ‘weather’ is used in the name. However, I did get results:
Regarding the Ecobee integration., I can’t help much with that as I don’t have one of those units. Are you using the DTH from @yvesracine. That is the only one that supports the tips…the native Ecobee does not as I understand it.
