[NO LONGER SUPPORTED] Ask Alexa
Oh, that’s weird. I seem to have two Amazon.co.uk accounts with the same email address now. It worked by the way, but it has lost the other settings (such as my prime account). It won’t let me add the Household account because it is the same email address.
Doh!
I guess I’m going to have to start from scratch again and try and make sure it is my correct Amazon account that is on the developer account. I guess I assumed (idiotically) that having the same email address would be sufficient for the accounts to be linked, but obviously not.
I’ll have to start again tomorrow. Thanks for the heads up (and the quick response)
Lee
Just wanted to post a quick thank you to Michael. I started from scratch and installed everything today. In total, including setting up the developer and lambda accounts and getting it all set up and configured, it took a little over an hour and Alexa responded with the correct information on my very first query :slight_smile:
Thank you for sharing your work with the community and in particular for your extremely detailed and comprehensive instructions, everything worked flawlessly right away at my end, thank you!!
PS - I changed my invocation phrase to “the house”, seems a bit more natural to say “Ask the house about the Garage” or “Ask the house to turn on x”, rather than “Ask Smarthings…”. It has a higher [WAF] (https://en.wikipedia.org/wiki/Wife_acceptance_factor) as well :wink:
One minor question - if I add new devices, sensors or routines etc in to SmartThings, do they need to be manually added in to the Custom Slots in the Interaction Model or is there some communication back from ST that will update those? I suspect it’s the former, but figured I’d check.
Glad you liked it and your first try was a success!!
Unfortunately any change to the devices or macro names required manual intervention with the slots. This is certainly a pain, but honestly, it only takes a few moments and it becomes less and less as you stabilize your config. I personally haven’t changed my slots in about 3 months now.
Good luck!
That’s what I thought, no big deal at all. Thanks again for all your work on this!
I installed this a long time ago. What is the best way to see if I am running the latest version?
Is there a github repo to add?
Also, why wouldnt the harmony hub be in the smartthings devices?
All of the versions are listed in the documentation. As for the Harmony…are you saying it doesn’t show up in SmartThings? Or in the app (Ask Alexa)?
in the app Ask Alexa.
What I really want to do is have Alexa through ST launch a movie on Plex? Or pause a movie? The logitech harmony skills in alexa arent pausing my nexus player or Mi Box.
Just wanted to say a huge thank you. I managed to set up the developer account again with the same user name and password as my Amazon account (it was the password that was wrong) and it worked fine.
The AskAlexa wiki instructions are outstanding and it’s only my own idiocy (and I guess an oversensitivity to duplication of passwords) that meant I went wrong.
I now want to take it to the next stage and get Alexa to make a statement if there is a motion sensor detection. I feel like this is possible and I think it is probably even clear in the Wiki, but maybe I’ve read it too many times and can’t see the wood for the trees. Can someone point me in the right direction?
I think it must be in voice reporting but I can only seem to figure out how to do a voice report when I tell it to don something, not when Smartthings does. Maybe it needs an IFTTT but I think it doesn’t.
Thanks.
Alexa needs a voice command. I don’t think there is a way to have a sensor activation cause an action by Alexa.
The Echosistant app might be closer to what you have in mind. I haven’t installed it, but it will send voice messages to echos.
Thanks. I’ve had a quick look, but EchoSistant seems to need Smartthings connected Speakers. I don’t have any of those right now, I was hoping I could get Alexa to do it. She’s got her own speaker after all. I guess she’ll just have to sit in the corner with a triangular hat with a D on it and think about her life choices.
Unfortunately, there is no way to push a message to an Alexa enabled decide… Amazon still hasn’t released that feature.
I haven’t read all of this thread so I apologize for the question.
Do we need to remove the ST Alexa app to use Ask Alexa?
No…they work together very nicely.
I have no idea since I don’t have that device to test it…does the remote show up as simply buttons in SmartThings, or something else? That can certainly be added…I just need to work with someone who has one (or someone would need to donate some money to get me to purchase it so I can test it).
You will not be able to do that with the stock Ask Alexa. Alexas, by design, CAN NOT initiation a conversation or make a statement or noise on their own without a voice prompt. Amazon says they MAY open this up someday, and when they do I will support it…but for now you are limited to linking your Alexa to a Bluetooth device that will respond to actions within your home.
Michael,
I am trying to run the pause command on Plex.
I said Alexa, tell Smartthings to Pause Plex Mi Box
(This doesn’t really work through Harmony: see here
Pause Plex or AndroidTV through Harmony/St and Alexa)
It doesn’t do it and I see an error in the logs
What do you mean in ST? The remote is in Harmony which links to ST via the skill.
The Plex Mi Box has to be added to the slots. Again, I have no idea how this might work as I don’t have any of these devices. I would assume that Plex Mi Box is some sort of virtual switch? If so, it will need to be added to the app, then the name added to the Amazon developer slots. However, if it IS a switch, “pause” is an invalid command for that type of device. Pause will only work for speaker devices.
I know this is confusing, so I hope I am answering your question.
It is a Plex client running on a hardware called mi box. I added it to speakers already, if that is what you mean.
Any device added to Ask Alexa that you wish to control need to be added to the Amazon developer slots. Run the Setting-Setup variables then populate the slots on developer.amazon.com. http://thingsthataresmart.wiki/index.php?title=Ask_Alexa#Interaction_Model
Looking at your screenshot you will have some difficulty controlling these devices as items like “(” or “)” and with so many things having similar name. I recommend renaming them or setting up some aliases within the app so you can smoothly control these.
