Hi,
I have a problem connecting my mini-plugs to Smartthings hub v.2.
I have 2 Nexa AD147-2 Dimmer mini-plugs and had them used with Smartthings hub v2 and the classic app. Everything worked perfectly.
I then migrated to the new smartthings app and still everything worked fine. Then I accidentally removed location in the classic app and now I’m in trubbel.
First of all don’t delete location, unless you want to start from beginning!
The problem that I have now is that when I set the dimmers in inclusion mode, by pressing the button 3 times during 1,5 sec and push and hold within 1 sec until the buttons light turns off, the Smartthings finds them as “Everspring remote control” !!!
This make no sense. I have repeatedly removed them, by exclusion process, and add them again but with same result.
Does anyone else have the same problem? I welcome all tips and tricks.
Thanks in advance
