SmartThings Community
New Virtual Thermostat With Device
Hi Eliot,
Thank you very much for your help. You have done a wonderful job!
I was able to adapt your Apps to control my boiler with Hive and with Danfoss LC-13 smart valve.
I am using your app but in a different way:
I have the Danfoss LC-13 smart valve and I am contyroling the boiler with Hive. These valve are “special”, in fact, they do not report back the temperature.
To be able to use it with the official supported DHT, i created a simulated switch for each Danfoss valve, and in WebCore I established some rules:
  • if the simulated switch is ON then the temp for the valve is 28 Celsius and
  • if the simulated switch is off the temperature for valve is 15 Celsius
  • if any simulated switch is ON , then the Hive Controler is set to 28 Celsius and
  • if all simulated Switches are off Hive Controller is set to 15 Celsius
After that, I used the simulated switch for creating the simulated thermostat in your App in conjuction with a temperature sensor in the same room with the smartvalve.
I have tested for 3 days and it is working fine, I am very happy, I can control each room temperature, and it is ActionTile compatibile, I can use also with Alexa.
Can I sugest you some improvements?
  1. The most important is to be able to select a smart valve instead of a switch (when the switch is ON to setheatpoint for valve to maximum and when the switch is off to setheatpoint for valve to maximum).
  2. To be able to control a real thermostat as a master thermostat which is controling the boiler
  3. To add a temperature variation for each temperature sensor (for example in one room I am using the window sensor to report the temperature, and ussualy the window temperature is less than room temperature with 2-3 celsius degrees, and it will be a nice feature to be able to set the room teperature as the window sensor temperature + 2 degrees celsius)
Regards,
Dragos
Hi is there a way to increase temperature in the 0.5 interval and not just 1.0?
this feature is called threshold in the device. Go to Smartthings app classic- The Automation TAB - SmartApps - Virtual Thermostat Manager. Over there you can see all your virtual Thermostat that you created. tap on one an d change the field called “Temperature Threshold” from default 1 to 0.5. After that dont forget to save in the top right corner. That is all
Is it possible to use this just as a temperature controller that can be used in webcore? I don’t want to link it to a device, I just want a way to edit my wanted max temperature.
@eliotstocker is it possible to add support for multiple contact sensors ? tnx
Can anyone recommend a smartapp to run schedules? i.e. turn on/off at specific times and set desired temp. I’ve not had much luck with any smartapps as yet. They all seem to specify cooling modes which doesn’t apply to this app. TIA
You can use webCoRE to create your rules. It’s really easy to use once you get a hand on the terminology.
Thanks for the suggestion. However, I already use webcore and was hoping for something in a smartapp for flexibility and ease of use. It seems like such a simple thing, I’m surprised there’s nothing available. Maybe this will be my first smartapp! The routines are so close to achieving what I need, but there is no option to turn on the thermostat, only change the temp at a desired time.
If time happens at x
Then with therm set temp
Repeat steps.
It’s that easy
@Modrica You can create a virtual swich to be controlled by this app. After that you can setup some rules in WebCore or in the Automation in new version of Smartthings phone app. This rules are to mirror the state of virtual switch to a real switch device. In this way, you can control multiple real switches or contact sensors.
any way to add a basic schedule to this?
I have a Virtual Thermostat set to turn on a heater in our TV room in the basement but I only want it to monitor from like 3pm till midnight Mon-Fri. 9am till Midnight on Sat and Sun. Nobody is down there the rest of the time so no need to heat. but the door at the top of the stairs is always open so the cats can get to there food and bathrooms…
I have another VT setup to monitor the sunroom and I am using the door open sensor and this works great. but that door open is different than the basement so I cant use it as a heating switch. No other switch at the moment that I could use that would only be open during certain hours.
nevermind, I setup a routine and setup when to auto adjust the temp up and down at specified times of the day.
Works perfect without having to add any additional code to this smart app.
the app works great on classic version but on latest version of smartthings it just reads the temps but you can’t modify the thermostat value. Is this still developed?any change to make it fully compatibile with new smartthings app or does anyone knows an alternative for the new app?
Is there a way to get this to run locally. I’ve been running this all winter and it works great.I Have multi able IR heating panels and a main heater, but lost internet last night without losing power and the heaters stayed on all night( was a little toasty in the house when i got up) usually i lose power and the internet at the same time
P.S great work on this
At the present time, no custom code can run locally. It all runs in the smartthings cloud.
The only things that can run locally are the official smart lighting feature as long as all the devices included are eligible to run like locally and a few parts of smart home monitor.
(And if you have the ADT model panel, its alerts can also run locally.)
But that’s it.
Hi guys
I would appreciate your assistance if possible. I tried to install the two parts but I ended up with a device named ‘Tiles Missing’ which cannot be removed from my home screen. I know it is a kind of stupid i did with the device handler but I don’t know how to remove it.
Any help/guidance appreciated
Thank you,
First off, great work! I’ve been monitoring this thread for a while, and am now beginning to implement these thermostats. I’ve successfully set up and built a piston in WebCore that mimics this functionality, but it is cumbersome and awkward https://community.webcore.co/t/working-thermostat-piston/5035. It requires feeding data into the setpoint and current temps of the Smartthings Simulated Thermostat. Another issue is the tendency for that device to automatically increase “current” temp values, requiring me to feed it readings every minute or so…
I wish to abandon that method and move all my thermostats to use this… however, I have two issues:
  1. I cannot get the Thermostat to show the set temperature in Fahrenheit - the “current temp” seems to use the hub preference, but the “set temp” still shows in Celsius
  2. Next is that this thermostat seems to turn the appliance switch off as required, but does not switch it on. I’m thinking that if item 1 is fixed (both readings are in °F versus a mix of °C & °F), this may fix itself.
Thanks very much for all the hard work!
I believe I found the answer to my problems! I missed the part about modifying the Thermostat Device Handler, and was trying to modify the Smart App to fix my Issues… Once I changed the “true” to “false”, my device operates as expected…
Hi
First bug i have encouncterrd since i got SmartThings. I have all thermostats showing ok, with the correct temp. But they don’t turn on the heaters. What can be wrong. The sensor values is correct. For example
Sensor value reads 20, heater set to 23. Wall plug doesn’t turn on.
I use fibaro wall plugs. I have 4 virtual thermostats with 4 wall plugs and 4 sensors. None of them are working. Or it shows that it’s heatinf to 23 degrees but none of the wall plugs are on.
Any tips?
@eliotstocker you still working with this?
