I think I got it… Missing a { at the end of the modified line.
So I’m noticing that the units aren’t cycling off at all, even with the modified code.
Is there a way to convert the entire device/smartapp to cooling only?
Is it as simple as replacing every instance of “heat” or “heating” with “cool” or “cooling” respectively?
Reversing the logic for the on/off in the modified code makes sense, but beyond that I get lost in syntax, so I don’t know what to change.
Finally, the thermostat temperature shows in F, but the adjustment for the thermostat shows in C. Any way to make it all F for us US savages?
Line 161 of the DTH and down has the Centigrade/Fahrenheit adjustment.
def shouldReportInCentigrade() {
//there is no way to do this dynamically right now, a number of the functions that call this function are compile time evaluated :(
return false //Set this to true for Centigrade, false for Fahrenheit so that enums and colors are correct (due to ST issue of compile time evaluation)
/*try {
def ts = getTemperatureScale();
retVal = ts == "C"
} finally {
return retVal
I’d like to echo the request for cooling support, and tweak the temperature setpoint to allow for 0.1 increments.
@eliotstocker happy to help with the above to the best of my ability, feel free to pm me!
Exactly what I am looking for using door sensor and temperature sensor to turn heater switch on/off.
Hi All Great looking app, will come in handy for sure but now, being one of the hottest summers EVER in Belgium for me, Cooling mode would be fantastic! Any news when thats ready or being worked?
I like your thinking
+1 on this - I’d like the heater option to be made optional too. My use case would be reporting only, it would be great if this could be implemented
Sorry to be a bit dim, but can someone explain how to set this up. I’ve copied the code for both device type handler and smartapp and published it. I added the device from within the IDE. Then the smart app from within smartthings app on my phone. When I add the app I get a page that says Thermostat Manager, Devices, New Thermostat. If I click on “New Thermostat” it just hangs waiting for ages then does nothing. I can click save.
I see the thermostat device, but don’t see how it works.
I was expecting at some point to say which device I am using to measure the temperature and which device it swhould turn on and off but haven’t done that anywhere.
I guess I’m missing something basic about the installation and setup process.
same issue; doesn’t appear to work; creates the virtual thermostat and captures the temperature from the sensor, but doesn’t record or save or allow me to set values / temp for the threshold
Anybody having issues with this? It doesn’t seem to turn off my heater outlet or turn it on.
It’s working for me. though I have been screwing with it for days. I finally just linked the repository then imported it and over wrote the piratemedia/smartthings : Virtual Thermostat With Device code with this
saved and published then
modified the handler to have this code at line 163 to get fahrenheit
return **false** //Set this to true for Centigrade, false for Fahrenheit so that enums and colors are correct (due to ST issue of compile time evaluation)
Very happy to find this solution!
Though, it does not seem to respect the “Door open” function. It just keeps on heating to the set temp even if the door is open. Anyone any thoughts on this?
Nope. Mine honors the door open. No clue what would be different. I have remmed a bunch of things out in the DH but that was just to turn off all of the different Temps because I only need 1.
From my example above I just changed the true/false value to give me f instead of c
Hi there,
I need some help with the set up please.
I have copied the handler code and create the new handler, then I have copied the smartapp code and create a new app from this code, both of them are published and active.
From the app on the mobile I can see the smart app and configure things, ok.
But I have two fibaro ZW5 sensors and I would like to read the temperature from Google Home assistant but I don´t know how to do this, I can´t see the virtual thermostat from Google Home, I can see the fibaro sensors but these do not report the temperature to google home. If I do add manually a virtual thermostat from IDE and select this handler, automatically I can see the new device on google home app and I can ask to google home about the temperature but I can´t select the correct sensor from where to read it, it select the same one all the time. Any help please ?
Any updates on cooling functionality? I implemented the mod posted by @BartschLabs but a cooling a cooling UI would be great.
I have the same issue: the thermostat starts heating even though the window switch is reported open.
//UlfThomas
Hi Eliot,
Thank you very much for your help. You have done a wonderful job!
I was able to adapt your Apps to control my boiler with Hive and with Danfoss LC-13 smart valve.
I am using your app but in a different way:
I have the Danfoss LC-13 smart valve and I am contyroling the boiler with Hive. These valve are “special”, in fact, they do not report back the temperature.
To be able to use it with the official supported DHT, i created a simulated switch for each Danfoss valve, and in WebCore I established some rules:
if the simulated switch is ON then the temp for the valve is 28 Celsius and
if the simulated switch is off the temperature for valve is 15 Celsius
if any simulated switch is ON , then the Hive Controler is set to 28 Celsius and
if all simulated Switches are off Hive Controller is set to 15 Celsius
After that, I used the simulated switch for creating the simulated thermostat in your App in conjuction with a temperature sensor in the same room with the smartvalve.
I have tested for 3 days and it is working fine, I am very happy, I can control each room temperature, and it is ActionTile compatibile, I can use also with Alexa.
Can I sugest you some improvements?
The most important is to be able to select a smart valve instead of a switch (when the switch is ON to setheatpoint for valve to maximum and when the switch is off to setheatpoint for valve to maximum).
To be able to control a real thermostat as a master thermostat which is controling the boiler
To add a temperature variation for each temperature sensor (for example in one room I am using the window sensor to report the temperature, and ussualy the window temperature is less than room temperature with 2-3 celsius degrees, and it will be a nice feature to be able to set the room teperature as the window sensor temperature + 2 degrees celsius)
Regards,
Dragos
