@Martin_Rourke, from the first time you installed this DTH, you weren’t able to see the parent there?
The 2 devices show up as separate devices in the app however only the child device shows up in the automations device list.
- the
supportedButtonValuesneeds an extra configuration on the Automations View because not all the devices use this property. This post has an example of this.
I’m not sure I understand the format of this. where would you add the following as per the example in your link and what attribute is controlling the addition to the automations screen. Where I’m a bit lost is to why the child device is working however the main one is not.
"automation": {
"conditions": [
"component": "button1",
"capability": "button",
"version": 1,
"patch": [
"op": "replace",
"path": "/0/list/supportedValues",
"value": "supportedButtonValues.value"
