hi notice there is a driver for samsung audio in the github edge drivers list but it is not in the beta list , is it posible to install the driver ? to test
thanks martin
@nayelyz
@Mariano_Colmenarejo
Just so you are aware, this thread pertains to Beta testing Samsungâs Edge drivers. These are not the production version. The beta versions, or even the production versions, may not be what you really want. 3rd party (community) developers also write drivers which are often more fully featured. Here is a link to a wiki that describes those drivers:
https://thingsthataresmart.wiki/index.php?title=Quick_Browse_Lists_for_Edge_Drivers
However, if you want to join the beta program for Samsungs Drivers, look at the link below. Bear in mind that a number of Samsung drivers are already in production, so I would remove and re-add your device just to make sure a Samsung production driver doesnât already exist.
Thank you Bryan
Good evening, I have a qty of Smartthings Zigbee Motion Sensors STS-IRM-251 (Motion, Temperature and Battery). They are not being picked up by the âZigbee Motion Sensorâ driver when I delete and re-add the device via the app (I have added the driver to my hub). It is being picked up as a (legacy) âZ-Wave Repeaterâ. I hope it is just a case of adding the fingerprint to the stock driver which I believe is: 89a26feb-d6d9-4e2f-9e6d-452be9464e5d
Thank you and Regards
Jim
hi just tried the samsung audio edge driver the tts (text to speach /notification ) isnt working and im not sure where to post this so i thought here .
thanks for the great work
martin
hi the zigbee window treatment driver please can you add a calibration to it
thanks
martin
I intended to fork the Z-wave window treatment driver to implement it for iBlinds, but when I looked at how Edge driver packages are assembled I got intimidated. Iâm not sure whether the capability is applicable to most devices or just a couple of particular manufacturers / models.
Hi, @montyfert
Could you elaborate, please? Is it something that used to be available in the stock driver?
in order to use the curtain driver it needs to know when the blind is open and closed and the time it takes from open to closed.
as is the driver only rruns the blind for 10 seconds then shows closed and vice versa
thanks
Hi,
Does anyone know of an edge driver for Livingwise 7 button zigbee scene controller?
LVS-ZB-SC7
Device ID: d57d0e58-d089-4d73-8aec-c5f6bd357949
Could I get the Aeotec Doorbell 5 fingerprint added to the Z-Wave Siren driver?
zw:L type:1005 mfr:0086 prod:0104 model:0038 ver:1.12
I see the version 6 is listed so would like to see if it works with this device as the official Aeotec driver isnât working.
Does anyone have other suggestions of a driver that may work for this device?
Thanks.
Aeotec has published a driver for the Doorbell 5 in their official driver channel.
They have but it doesnât work, or at least it wonât do anything except act as a switch and play the first track.
Could you please add Aeotec Siren (Gen 5) to the Z-wave Siren driver
Mfg Code: 0109-2005-0508
I have tried installing the edge driver for SmokeSensor-EF-3.0.
However I keep getting the message that the device did not upload all information yet.
Not sure what is going on.
This is the driver ID that Iâm using:
|Driver ID |a2f7ec78-14c8-492d-9965-7544b0fc3b68|
|Driver Name|Zigbee Smoke/CO Detector Mc|
Try pushing the test button on detector if you have not already done that.
Just makes my ears ring. Doesnât show anything in history
Try deleting and re-pairing it right next to your hub.
