SmartThings Community
New Sony Bravia TV integration for 2015 - 2016 alpha
dth_av
(Steve Bratt) #224
I dont think it is at least not via SOAP/Web requests, but i could be wrong as im no expert.
(Patrick Mjoen) #225
I have changed the code to test the WOLC when I select to turn ON but that is not working either. Power Save is OFF.
(Kurt Jones) #226
Are there any detailed instructions on how to set this up? I feel I have followed what was originally posted but its not working. I have a feeling I am doing something wrong.
(Steve ) #227
The first post should do it for you.
What part you struggling with ?
(Kurt Jones) #228
I must be doing something wrong with the IP/Hex address part. Or it could
be the port number. The app isnt communicating with my receiver.
(Steve Bratt) #229
can you post some screen shots or photos of what your putting in to things and we can check them?
(Kurt Jones) #230
(Steve ) #231
that doesn’t look the same as mine
i entered it as hex in the main device settings but in the preferences its the normal ip
(ᵇᶥᵍ ШΞΒȘГẬŚ (Webstas)) #232
Which DHT code are you using? i love that look
(Kurt Jones) #233
(Kurt Jones) #234
I made the changes to mimic what you have. Still not communicating. Could
the issue be with port 80? If so, how can I check to make sure its open?
(Steve ) #235
Possibly but I’ve just checked my router and I’ve not needed to forward the port for mine.
Have you double checked the hex key details are right
(Kurt Jones) #236
I used a hex key converter for my IP address.
(Steve ) #237
Just ran your IP through a convertor so it sound be c0a80109:0050 is that what you have in device ID?
(Kurt Jones) #238
Yes that is what I have
(Kurt Jones) #239
I think I saw someone say they got it working with my model too. xbr55x850d
(Steve ) #240
What about the settings on your tv have you double checked you’ve turned all the settings mentioned above?
(Kurt Jones) #241
I double checked and the TV settings are just as instructed.
(Steve ) #242
I’m not sure then :frowning:
Have you given your TV a static IP ?
Make sure it’s not changed address.
(Steve Bratt) #243
are you sure your PSK is sony? i thought they had to be numbers not letters
